How do I fix code 0340 camshaft position sensor a bank 1or sensor n 462
Old Aug 5, 2017 | 01:04 AM
Charshycs's Avatar
0462 code fuel level sensor a circuit low how do I fix I changed my spark plugs n oil change it hard starting low power shuts offf sometimes when drivinggas gauge wrong half tank means empty ran out of gas a few times also uses a lots of gas idling is high
Old Aug 5, 2017 | 08:00 AM
telcoman's Avatar
Veteran: Army
Have you read the trouble shooting in the FSM?
http://www.nicoclub.com/service-manu.../Sedan/2012/EC
See page EC- 379
P0462, P0463 FUEL LEVEL SENSOR
Description
INFOID:0000000007462815
The fuel level sensor is mounted in the fuel level sensor unit.
The sensor detects a fuel level in the fuel tank and tr
ansmits a signal to the “unified meter and A/C amp.”. The
“unified meter and A/C amp.” sends the fuel level sens
or signal to the ECM via the CAN communication line.
It consists of two parts, one is mechanical float and the ot
her is variable resistor. Fuel level sensor output volt-
age changes depending on the movement of
the fuel mechanical float.
DTC Logic
INFOID:0000000007462816
DTC DETECTION LOGIC
NOTE:
If DTC P0462 or P0463 is displayed with DTC UXXXX,
first perform the trouble diagnosis for DTC
UXXXX.
If DTC P0462 or P0463 is displayed with DTC P0607,
P0607.Refer to
EC-406, "
DTC Logic
DTC CONFIRMATION PROCEDURE
1.
PRECONDITIONING
If DTC Confirmation Procedure has been previously
conducted, always perform
the following procedure
before conducting the next test.
1. Turn ignition switch OFF and wait at least 10 seconds.
2. Turn ignition switch ON.
3. Turn ignition switch OFF and wait at least 10 seconds.
TESTING CONDITION:
Before performing the foll
owing procedure, confirm that battery vo
ltage is more than 11 V at ignition
switch ON.
>> GO TO 2.
2.
PERFORM DTC CONFIRMATION PROCEDURE
1. Turn ignition switch ON and wait at least 5 seconds.
2. Check 1st trip DTC.
Is 1st trip DTC detected?
YES
>> Go to
EC-379, "
Diagnosis Procedure
NO
>> INSPECTION END
Diagnosis Procedure
INFOID:0000000007462817
1.
CHECK DTC WITH “UNIFIED METER AND A/C AMP.”
Refer to
MWI-38, "
CONSULT Function (METER/M
A)
Is the inspection result normal?
YES
>> GO TO 2.
NO
>> Go to
MWI-54, "
Component Function Check
2.
CHECK INTERMITTENT INCIDENT
Refer to
GI-43, "
Intermittent Incident
DTC No.
Trouble diagnosis name
DTC detecting condition
Possible cause
P0462
Fuel level sensor circuit
low input
An excessively low voltage from the sensor is
sent to ECM.
• Harness or connectors
(The CAN communication line is open or
shorted)
(The sensor circuit is open or shorted)
• Unified meter and A/C amp.
• Fuel level sensor
P0463
high input
An excessively high voltage from the sensor i..........
Telcoman
