2005 Infiniti G35 Battery Fuse
Old Aug 24, 2017 | 06:13 PM
KungPaoChicken's Avatar
Hi, after searching around the internet and not having any luck I have decided to join the likes of the fine people of g35 driver to get some help.
Earlier this morning my 2005 Infiniti G35 had trouble turning over. My father messed with it while I was at work and tore out the battery fuse. He says I need a new battery fuse and I am trying to find it online. I have had trouble finding that part for the 2005 specifically. Dorman makes a battery fuse part number 924-082 that is compatible with Nissan's and Infiniti's from 2015 to 2004. Unfortunately, a 2005 G35 is NOT on the list. I also chatted with their customer rep and they said Dorman does not manufacture a battery fuse for a 2005 G35.
So my question is...does anyone know where I can get one? A battery fuse for a 2015 G35.
I'm thinking about buying the battery fuse for the 2007 G35 and see if it works in my 2005. From pictures, it looks exactly the same.
Thank you in advance for any guidance.
Old Aug 24, 2017 | 11:00 PM
coffeysm's Avatar
That's the fusible links and it should work. You need to figure out what caused it to blow though. It.could happen again.
Old Aug 24, 2017 | 11:17 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
So you need a new fusible link carrier or you need JUST the fusible link (125 amp fuse that goes in the holder plus others) ??
The compatibility for the G35 should be:
  • 2003-2008 Nissan 350Z (Z33)
  • 2003-2007 Infiniti G35 Sedan (V35)
  • 2003-2008 Infiniti G35 Coupe (V35)
Try searching those other vehicles as well.
