Car stalling when turning
Old Aug 28, 2017 | 09:23 AM
bjo16's Avatar
hi I have a 08 g35xs and recently it's been almost stalling and has stalled twice I think, when making a turn. Doesn't have to be a sharp turn but usually it's at lower speeds like pulling into. A driveway or around in. A parking lot. Jist happened now as I was in. A parking lot and turned and almost stalled. Anyone know what this might be?
Old Aug 28, 2017 | 09:42 AM
gary c's Avatar
We've seen this before, use our Search! Like most issues this has already been solved...Gary
Old Aug 28, 2017 | 05:53 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Check the power steering pressure sensor. Values should read as such.
Yellow = 5v supply voltage
Black/white = ground
Blue white = 0.5 v while steering wheel not being turned, up to 4.5v while steering wheel IS being turned depending on load.
If you don't see the values increasing while the steering wheel is being turned then the switch fried, somewhat common and easy to troubleshoot.
