Surprising Oil Analysis Results... is dino better than synthetic?
Old Mar 4, 2005 | 12:22 PM
trebien's Avatar
Originally Posted by copbait
Ahh ok, so the particles are actually microscopic in size. That clears up some of my confusion then, thanks =)
If they're not microscopic (shavings), you've got serious problems....
Old Mar 4, 2005 | 05:10 PM
chinee's Avatar
Originally Posted by 3Aims
Very interesting thread. I don't understand how M1 is inferior?
I'm not quite ready to make that leap yet... only speculating as to the results I've had with my VQ. What the analyses positively show is that there's less wear with Pennzoil dino than with Mobil1 synthetic. I would have thought the opposite to be true.
Others have speculated that they've had similar results with the 4.3L GM V6, and maybe Mobil1 and these engines are just not a great match. It happens...
I can tell you that Mobil1 in my wife's Sequoia is a match made in heaven. I can go 9000 miles (maybe more) between changes without concern. So I'm not knocking M1... just exploring the results oil analyses have presented to me.
Old Mar 4, 2005 | 08:19 PM
nov0798's Avatar
I use Amsoil in all of my vehicles. Never had a problem
Old Mar 4, 2005 | 09:13 PM
IP05G35's Avatar
Switch to Mobil 1 5w-30.
Old Mar 4, 2005 | 09:18 PM
copbait's Avatar
Old Mar 4, 2005 | 10:44 PM
chinee's Avatar
5W30 is a thinner oil that provides less protection. In fact some are saying that even Mobil1 10W30 may be too thin for this application.
Old Mar 4, 2005 | 10:56 PM
chinee's Avatar
Originally Posted by Bazz
I'm in full agreement. I have run M1 in all my cars since 1987. My 87 Honda CRX-Si I bought new in 87. Changed the oil to M1 after 2000 miles. Drove that car hard for 13 years changing the M1 oil and M1 filter every 5000 miles. Finally sold it after 13 years of hard driving and frequent weekend autocrosses. It had 218,000 miles on it and right before I sold it I had Precision Honda in Pleasanton, CA do a compression check for ****s and grins. The CC showed that I still had 92% of full stock compression after 13 years and 218,000 miles. I have run M1 in all my cars since then. I did run 10W-30 though...
My last car was a 96 Altima that always got Castrol GTX of varying viscouities, 5W30, 10W30, 20W50, etc. whatever was cheapest at the time. Used Fram filters cause I liked that black matted grip on the end of the filter. My oil change interval was "whenever-I-got-around-to-it", usually anywhere between 5K and 12K miles. I hardly ever checked the oil or topped up. Sold it at 170K, never had an oil related problem, car still ran great, had decent power, and was still running with 190K the last time I saw it.
So I believe that oil may not necessarily play as substantial a role in an engine's life as much as many of us want to believe. So I do oil analysis not to extend my VQ's life, but more as a hobby than anything else. It may simply be that M1 and VQ just don't go well together.
Old Mar 4, 2005 | 11:19 PM
ARH_twilightblue's Avatar
Well the logical next step would be a 40wt such as M1 0w40 or something close to a 40wt such as German Castrol 0w30. I will personally do UOA's with both of these oils once I'm past 10k miles to see if they are better then the Pennzoil 5w30 dino I'm using now. Would be interesting to see if our VQ's are happer with an A3 rated oil such as those two.
Old Mar 4, 2005 | 11:53 PM
nov0798's Avatar
what range does the owners manual say you can use? I run 0-30 in my current car.
https://www.amsoil.com/performancete...vs_mobil1.aspx
Old Mar 5, 2005 | 01:40 AM
WolfsterX's Avatar
I'm sooooo confused! Let's get to the point! Is Mobil 1 Super Sync. a good product or not? From what i heard that Infiniti hasn't test the Sync. oil for the VQ Engine. Correct me if I am wrong. Can someone make a main point of MOBIL 1 of advantages and disadvantages.
Thanks
S.
Old Mar 5, 2005 | 02:51 AM
6MTsdn03's Avatar
Very interesting results but was the M1 5W30 or 10W30? your test results posted at the http://www.g-owners.com says that it was 10W30.
Old Mar 5, 2005 | 02:54 AM
6MTsdn03's Avatar
exact link http://www.g-owners.com/pic_display.asp?id=332
Old Mar 5, 2005 | 02:57 AM
  #30
copbait's Avatar
What do you mean they are posted right on the report itself, they are both 10W30:
