Lack of power
Old Mar 12, 2025 | 10:38 AM
Vqdrew's Avatar
G35 brembo, 6mt
Lack of power
2003 g35 coupe. Z1 air filter. Plenum spacer. Tomei headers. Catless dp. Custom 3” exhaust
my fuel trims are all messed up, the only codes i have are for downstream o2 sensors and i thought those wouldnt affect my air fuel?
Old Mar 17, 2025 | 06:34 PM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
Have you checked to see if the accordion connections for the intake tube are torn? If they tear they can cause all sorts of issues because air is entering the engine after it goes past the MAF sensor. Z-1 has some urethane replacements.
Old Mar 17, 2025 | 07:40 PM
Vqdrew's Avatar
G35 brembo, 6mt
i have the z1 cold air. Ill smoke test the intake and the whole vacuum section and see if thats it, thank you
Old Jun 3, 2025 | 04:01 AM
Calibenjamins's Avatar
G35 coupe base model w nav
what are you using here to monitor everything ?
Old Jun 3, 2025 | 09:12 AM
Vqdrew's Avatar
G35 brembo, 6mt
its just a obd scanner that has live data, connects to an app called repairsol2
Vqdrew
Apr 3, 2024 08:52 AM
ristau5741
May 16, 2013 10:51 AM
gymkhana
Aug 27, 2012 06:15 PM
vodkarocket
Intake & Exhaust
Sep 15, 2005 01:44 PM
neffster
May 1, 2004 08:39 PM
