Noise question...
Old Apr 10, 2005 | 10:08 PM
eldy's Avatar
Noise question...
Is the hissing noise at approximately 2500 rpms bad?
<embed src=http://members.dslextreme.com/users/g35driver/noise.wmv autostart="n">
Old Apr 10, 2005 | 10:56 PM
WRAH's Avatar
WRAH
I don't know..... Try not Reving (up & down), and try holding it steady at where you hear the noise and then re-post.
That & (I'm no expert on this) but should you be reving in N not P?
Old Apr 10, 2005 | 11:28 PM
eldy's Avatar
There is no hissing when I hold the revs up. There is only hissing when I'm completely off the throttle and in the 2500 rpm range.
Old Apr 11, 2005 | 12:08 AM
THX723's Avatar
G Kreuzer
It's a rattle that sounds much like a hiss. You simply excited one of the metal pieces (likely a heat shield/panel), which is not uncommon at between 2500-3000rpm. I had the same *exact* thing when I ran test pipes before finally getting rid of them.
Old Apr 11, 2005 | 12:27 AM
eldy's Avatar
The car sounds horrible when the exhaust is still cold... I might just save up for some high flows or put the kitties back on and get a y pipe or sumptin'.. I was gonna get a y pipe next anyway..
Old Apr 11, 2005 | 02:35 AM
Vic's Avatar
Vic
is your car stock? coz I have the same sound as your car. However, I have installed the crawford cats and gruppe-s y-pipe.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
