Blackstone Reports
Old Apr 12, 2005 | 09:33 PM
FLFIRE's Avatar
Blackstone Reports
My first two Blackstone Oil sample reports are listed below. I will keep this thread updated as I get additional reports. Great justification for oil changes prior to the 3,500 mile mark.
Attached Thumbnails Blackstone Reports-blackstone-1.jpg   Blackstone Reports-blackstone-2.jpg
Old Apr 12, 2005 | 09:35 PM
FLFIRE's Avatar
As an FYI, I mistakenly indicated 10w-30 rather than 5w-30 on the first report.
Old Apr 16, 2005 | 10:25 AM
FLFIRE's Avatar
Latest Blackstone report. Copper really came down. They still have me as a 10w-30 but, it really is a 5w-30 as was picked up in the test.
Old Aug 2, 2005 | 06:45 PM
FLFIRE's Avatar
Fourth Blackstone report. First report on Mobile 1.
Old Aug 2, 2005 | 07:25 PM
neffster's Avatar
Tony, it's too small to see (either that or I'm just gettin' old). What does it say and why the...
Old Aug 2, 2005 | 07:32 PM
Finiti35's Avatar
FGC South Florida BOD
It says that copper and silicon levels have gone up after they've been improving thus far and if his engine has been open for work, this could have caused it. I talked to someone who is a chemical engineer on here who recommended against switching to synthetic before 10-12K miles, I can't see how many you have on the paper, but I'm not too sure what to think about it either. I too am going to need a blackstone test to determine how often oil changes are needed..
Old Aug 2, 2005 | 07:40 PM
FLFIRE's Avatar
Hoping for better with Mobile 1. I changed the filter at about the 4,000 mile mark, so that is not it:
Copper and silicon both increased quite a bit in the latest sample from your Infinity. Both
had been improving up till now and should have read closer to average in this sample. If this engine
has recently been opened for work, then that may have caused the readings. Else, if the high silicon
is from a dirty air filter, that may have caused the excess copper. The TBN was 3.5, which is down a
little from the 4.2 last time, but still a good reading. Suggest resampling this engine in another 3,000
miles to monitor and check your air filter. Hopefully things improve.
Old Aug 2, 2005 | 07:55 PM
Finiti35's Avatar
You need to talk to TimW, he's the blackstone expert on here. I will be contacting you later on before I send a sample myself. Keep us posted.
