squealing UR pulley
Old Apr 15, 2005 | 09:49 PM
jadaway2's Avatar
squealing UR pulley
Got the blue annodized UR pulley put on about two months ago. Not long after the damn thing started squealing when started cold. Only squeals for 1 minute or less at startup and only when cold.
Got it checked out and they said nothing wrong. Belt is on correctly and adjusted. Put on the gates belt that came with the pulley.
My theory is that the dew collects or something like that and the annodized metal lets the belt slip.
Anybody else have this problem? I scuffed the pulley today with sandpaper and we'll see. It's driving me nuts.
Old Apr 15, 2005 | 11:33 PM
g3po's Avatar
belt squeel
It's not the pulley , it's the belt.
Even though "they checked it", the belt prolley isn't tightened to spec.
Loose belts will make a noise when cold. If you don't use a gauge , tension is guess work. The device I use to get in spec repeatable tension is the
" Krikit-2".
Old Apr 15, 2005 | 11:44 PM
copbait's Avatar
The install instructions say to re-adjust the belts after 100 miles. This usually just involves tightening the belts as already indicated.
Old Apr 16, 2005 | 12:11 AM
DaveB's Avatar
Just tighten the belt fractionally more and see where that gets you. What's the belt deflection spec on these cars?
Old Apr 16, 2005 | 02:32 AM
Sickone's Avatar
yep - I can assure you it is loose belt(s) tighten them a tad, most likely it is the forward belt that runs the alt/powre steering
seagrasser
May 3, 2022 09:43 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
NailBomb
Oct 28, 2015 07:53 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
3000vr4tt
Sep 7, 2015 12:48 AM
