CAI Bypass Valve
Old May 16, 2005 | 04:27 PM
JC79G35's Avatar
Question CAI Bypass Valve
Well, I finally found a bypass valve for my AEM CAI. I've heard that you need to cut the pipe in order to install this. Has anyone done this before? Any advice would be much appreciated!
Old May 16, 2005 | 08:24 PM
jnkirk1974's Avatar
Fastest G35 In Rockwall
How do you guys like your AEM? I just got mine installed. Curious to see what you guys think.
Old May 17, 2005 | 02:43 AM
GReddySetGO's Avatar
Yes, you have to cut your pipe with the AEM. You have to cut out like a 2-3" section of pipe, the bypass valve comes with instructions and pictures. When I installed it on my Injen intake, I just put it in between 2 pipes instead of using the coupler.
Old May 17, 2005 | 01:08 PM
JC79G35's Avatar
I love it! Probably one of the best intakes you can get for the G35.
Old May 18, 2005 | 03:41 AM
Silverbolt's Avatar
I cut mine.. not for the bypass valve, but to do a little customzing
All you need to do is hit it with a hack saw. Even a dremel with a cutting bit will do. The cut doesnt have to be perfectly straigt, since the sleeve/bypass valve will be covering the edges. And be sure to wash out all the metal shavings inside the intake pipe before you reinstall it. All that metal shavings inside your motor isnt a good thing
Old May 18, 2005 | 08:03 AM
Also might want to put some paint or clear coat over the unfinished metal to prevent it from rusting.
Old May 18, 2005 | 01:13 PM
jnkirk1974's Avatar
I heard a rumor.......
Is it true that AEM makes the Nismo CAI? If so, how many other Nismo products are created by other companies?
And, if this is the case, then Nismo is REALLY ripping people off.
Old May 18, 2005 | 03:12 PM
AEM makes the TRD cold air for the Toyota Matrix/Corolla.
Old May 19, 2005 | 04:27 AM
Silverbolt's Avatar
Aluminum doesnt rust. The 6061 series (standard) of aluminum has really good corrosion resistance. But if its left submerged in a salt water, it will eventually corrode. So as long as you dont mix up your G35 with your submarine, you should be ok
Once aluminum is placed in an oxygen environment it builds a protective layer of oxidation. Although this layer plays havoc during any welding process, it does protect the aluminum from many outside elements.
Old May 19, 2005 | 07:59 AM
Cool, good info
Old Jun 8, 2005 | 01:35 PM
JC79G35's Avatar
I installed the bypass valve last week. It took me a whole... 2 minutes. All I did was remove the first connecting sleeve and replace it with the bypass valve. No cutting needed. I'll post pics up as soon as I get a chance.
Old Jun 8, 2005 | 02:23 PM
Cool, thats how I did it with my Injen. I'm not familiar with the AEM, didn't know you could do the same on that one.
Old Jun 8, 2005 | 03:27 PM
anish3232's Avatar
I have a Sedan and I installed the Injen intake the filter itself is pretty much hidden its not visible from the outside unless it look at it very very closely. How can your filter get in water, the bottom is covered up and the car sits bout 10 inchs off the ground. Maybe in the coupe you can see the filter through the front bumper but the sedan is pretty much hidden in the far right corner of the bumper
Old Jun 8, 2005 | 05:05 PM
Reguardless, the only way to suck up enough water to hurt anything is if you submerge the filter, and to do that you have to drive through a puddle like a foot deep. And if you're doing that you're an idiot anyway.
