Hotchkis swaybar settings question?
Old May 29, 2005 | 10:24 AM
g35cas's Avatar
I am installing hotchkis swaybars, and would like some feedback on settings. I would like to get less understeer for more of a balanced feel. Even a little bit of oversteer would be fine. I was planning on just using the medium settings on front and rear. I am running Z springs and stock shocks, so pretty much stock at this point. Thanks for the feedback.
Old May 29, 2005 | 01:42 PM
MEECHIN's Avatar
If you're rolling on stock wheels, i wouldn't take it above Med/Med. (Front/Rear)
If you're rolling on 9.5 or 10.5 in the rears, you could go up to Med/Hard. (Front/Rear)
I've tested myself and it just seems that the HARD setting on the stocker wheels+tires is a bit too much. The rears would break free on just about every spirited turn i made. It's great for drifting.
However, the Med/Hard setup seems to go exremely well with bigger wheels+tires. The reduction in the roll inside the cabin can definitely be felt as well.
ENJOY!
Still one of the best mods i've done to date, if not THE best.
Old May 29, 2005 | 02:16 PM
tony's Avatar
Thanks for the feedback Meechin, I have wider wheels and tires and I put the setting on med/med. Its pretty easy to change the settings right? Just jack the car up..unscrew the bolts then adjust..
Old May 29, 2005 | 03:03 PM
MEECHIN's Avatar
Yep. Pretty easy.
Old May 29, 2005 | 03:32 PM
tony's Avatar
what are the torque specs so I don't go too lose?
Old May 29, 2005 | 03:59 PM
MEECHIN's Avatar
not sure what the torque specs are.
never heard of any issues with overtorquing tho.
Just don't shred the threads. Just enough to make sure it doesn't come loose.
Old May 29, 2005 | 11:30 PM
g35cas's Avatar
Thanks for the feed back. I do have stock wheels, so I will go with the medium front and rear. Hotchkis has the torque spec's at 40 lbs. Thanks again.
jsimonk
Dec 22, 2023 03:49 PM
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
Th611
Oct 27, 2015 03:48 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
mushu
Jul 15, 2015 03:55 PM
