quick question about z tube
Old Aug 22, 2005 | 08:01 PM
realgone's Avatar
Widdle ya into kindling
While attempting, not so well, to install the z tube, I got to the point in the first pic and then decided it was too much. I loosened the clamp on pic 2. My Q is how tight do I need to tighten the clamp back up. Kinda nervous about driving it now.
Attached Thumbnails quick question about z tube-1.jpg   quick question about z tube-2.jpg
Old Aug 22, 2005 | 08:39 PM
ryansg35's Avatar
Future Sedan Freak
not to tight just enough where you can no longer turn the screw with minimal force
Old Aug 23, 2005 | 12:34 AM
SI_G35Coupe's Avatar
Z tube requires 3 connections total... 2 hose clamps (arount the tube, tighten with a 10mm socket or a philips screwdriver) and that breather hose you show in the first picture
to loosen or tighten the breather hose, just get a pair of pliers and squeeze the two tabs together, the clamp will loosen. then slide the hose and clamp onto the nipple of the Z-tube and release.... should tighten up no problem.
as for the two hose clamps, you just need to tighten them until the tube is totally secure... you'll know when, b/c you won't be able to pull the connections out.
then just replace the screw that holds the Z-tube bracket onto the plenum (near the oil cap) and you should be good to go.
Th611
Oct 27, 2015 03:48 PM
yosip1115
Engine - Intake/Fuel
Oct 16, 2015 11:37 PM
w4kj4k
Oct 7, 2015 01:26 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 18, 2015 12:33 PM
