ECU/Zeitronix wiring help
Old Aug 30, 2005 | 08:21 AM
g8tor20's Avatar
FGC's official flip flopper
Okay guys. Had the Vortech put in last weekend and the shop hooked up the Zeitronix along with it. It works perfectly except the RPM signal that the laptop reads out. I can't make it read right. Here is what Zeitronix said:
"You need to connect the Zt-2 RPM wire into one of the coil drivers from the ECU...Zt-2 green wire is the RPM pick up.
You need to find your car ECU wiring diagram to determine which wires are ignition drivers"
So...can anyone interpret this for me? The shop that installed it is 7 hours away. Is this easy to check? Any help would be great as I need the RPM's to read right so I can check my correct a/f levels. Thanks
Old Aug 30, 2005 | 01:27 PM
SFLG35's Avatar
FGC President
g8tor20: eric connected it to the crank position sensor wire already so it should read right
ask zeitronix what the voltage has to be on that wire aka what it needs to stay between.
the crank wire goes from 0 - 12 volts and averages 1.2 volts according to the service manual.
let me know what they say about the voltage and we can find a wire that will work.
Old Aug 30, 2005 | 01:43 PM
g8tor20's Avatar
I asked them. I'll see what they say. Do you think the unit could be bad?
Old Aug 30, 2005 | 01:48 PM
SFLG35's Avatar
FGC President
not sure
but we will find you when you get and answer from them
make sure to ask them if using a rpm wire that goes between 0 - 12 volts is ok
Old Aug 30, 2005 | 11:03 PM
baileyrx's Avatar
rpm lead is 0-5volts square wave, tach signal or primary(low voltage) side of the ignition coil. I'm reading my green sheet that came with mt set-up
Old Aug 30, 2005 | 11:12 PM
baileyrx's Avatar
hey,
on the ECM harness connector layout its lists the following PIN #'s:
pin 60 ignition signal no. 5
pin 61 ignition signal no. 3
pin 62 ignition signal no. 1
I would try any 1 of these to get a rpm signal
voltage is 0.1 - 0.4 on each lead
Old Aug 30, 2005 | 11:19 PM
baileyrx's Avatar
the location of these pin are as follows:
looking at the ecm connector terminal layout, you'll notice
on the far left; pins 1-5 in a group together(larger in size)
then to the right you'll see to more blocks of smaller pins.
the top block contains pins 6-43
the lower block of pins contains pins 44-81
62,61,60 are in the lower block, top row all the way to the left!
hope this helps
Old Aug 31, 2005 | 07:35 AM
neffster's Avatar
Side note... Bailey, that bracket you made and sent out to Jason was AWESOME! Really cool of you to do that, especially for the price you charged. Might consider selling those brackets for $29.95 and making a few bucks.
Old Aug 31, 2005 | 08:00 AM
g8tor20's Avatar
Thanks Bailey....I'll work on getting that right.
YES...the clip is awesome and works perfectly!!!! It had many compliments at our recent dyno day meet. Props to you...
Old Aug 31, 2005 | 09:24 AM
SFLG35's Avatar
FGC President
yeh that clip is pretty cool.
looked in the service manual jason
got it all figured out. pin 62 yellow red wire.
Old Aug 31, 2005 | 10:08 AM
KraftBMW's Avatar
what bracket? please post a pic.
Old Aug 31, 2005 | 08:34 PM
baileyrx's Avatar
thanks guys,
Heck, for $29.95 I'd include shipping! haha
Attached Thumbnails ECU/Zeitronix wiring help-supercharger-009.jpg   ECU/Zeitronix wiring help-supercharger-012.jpg
Old Aug 31, 2005 | 11:03 PM
booger's Avatar
I'll take one . When can you have one made up ? I have mine velcroed to the top of the dash . I like it there but the velcro doesnt hold up in the sun . Pm me and I"ll send the money when you get it made up ....Bill
Old Aug 31, 2005 | 11:06 PM
g8tor20's Avatar
Its worth it dude. Perfect place and perfect clip.
Old Sep 1, 2005 | 09:17 AM
neffster's Avatar
I want my 10% cut!
