Injen CAI & the Foam Block
Old Sep 21, 2005 | 01:02 AM
Triple8Sol's Avatar
From what I've read, some people are removing the foam block completely, while others are just cutting 1/2 of it off.
How is the foam block attached?
Basically I'm trying to find out how to remove it the easiest. Does it really require removal of the front bumper, or can it be done by just peeling back the splashguard in the wheel well
Thanks!
Old Sep 21, 2005 | 01:44 AM
Jtrain's Avatar
You can peel back- thats the easiest
Old Sep 21, 2005 | 01:46 AM
jtrudeau's Avatar
When I installed mine, I removed the front wheel and pulled the splash guards back and with a firm grip pulled the foam block out. I didn't have any problems at all. If you go to K&Ns site, they have a good DIY online.
Old Sep 21, 2005 | 02:22 AM
Triple8Sol's Avatar
Thanks for the heads up! Checked out that K&N installation instruction sheet. Very informative. Basically 3 more of those plastic rivets hold in the plastic shield that holds the foam block snugly.
Here's the direct link: http://www.kandn.com/instructions/69-7080.pdf
When I tried to install the CAI I just peeled back the splashguard in the fenderwell. From that side, you can't see those rivets, so I couldn't figure out how to get that piece out. Without removing that, the filter wouldn't sit properly...
Old Sep 21, 2005 | 02:36 AM
Hooman6MT's Avatar
20 Year Member
There's one rivet in there that's hard to get out, the one on the front. If you shake it enough it will come out. I tried to install my Injen CAI with the foam block in, but there was no way.
As stated above...pull it...
Hooman
Old Sep 21, 2005 | 02:04 PM
Hooman6MT's Avatar
20 Year Member
Originally Posted by S.E.
is this the same foam block that holds the front liscense plate filler peice in place on the 03 sedans?
No I don't think so. This one is on the side of the bumper right when you peel back your front inner fender lining
Hooman
Marlin84
Apr 1, 2020 12:52 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
dorkstar
Engine - Exhaust
Sep 9, 2015 07:43 PM
