Anyone receive their skunk2 plenum spacer?
Old Sep 29, 2005 | 01:39 PM
jwg35c's Avatar
Almost 3 weeks still no word.
Old Sep 29, 2005 | 02:24 PM
JohnNJ's Avatar
I have been watching these threads closely because I love Skunk2 and it seems to me that the only person that has one on thier G has the prototype version that was developed on their car...
Old Sep 29, 2005 | 06:26 PM
GGG's Avatar
GGG
My is on the way from ups....suppose to receive it tomorrow
Old Sep 30, 2005 | 01:23 PM
JohnNJ's Avatar
Thumbs up
You lucky F! Please post pictures of what you get and some after the install... I am thinking that Skunk2's spacer is going to become just as popular as the Motordyne spacer with the thermal package....
Old Oct 3, 2005 | 06:18 PM
GGG's Avatar
GGG
ok.. got it installed today during lunch.. took longer than I thought (2.5 hours) now I am hungry!
Items installed: Skunk2 plenum spacer, Motordyne thermal gasket
The material that spacer use is nice..feel like very hard plastic but yet light for it's size. Combine it with thermal gasket, it should work even better
and here's some pictures from the install...
http://gnuts.com/spacer.html
Old Oct 3, 2005 | 06:25 PM
DaveO's Avatar
I highly recommend that you find a way to replace the two missing studs with bolts. If you haven't already done so, you might try loosening all the bolts and see if a little "wiggling" will allow these two bolts to start by hand.
Old Oct 3, 2005 | 07:19 PM
GGG's Avatar
GGG
I did try the little wiggling thing..more than once , but it does not help at all because all other bolts line up correctly.
I just test drive it eariler (drop a coworker off) I notice the drive is actually better than before. Especially the first 3 gears... hmm.. maybe my mind is playing a trick on me? Anyway.. out of this 30 min drive, I don't have any problems.
And just for fun, I try to touch the plenum right after I stop the car.. and YES, it's hot but not burning my hand (lucky) only place my hand on it for 1 sec... hehhe...
Old Oct 3, 2005 | 07:44 PM
jwg35c's Avatar
Got my plenum spacer today. Problem is they forgot all the washers and bolts. I'll let them know tomorrow. Just hope it dosn't take long for the rest of the pieces.
Old Oct 3, 2005 | 07:45 PM
jwg35c's Avatar
Do you really have to drain the engine coolant per the instructions?
Old Oct 3, 2005 | 07:50 PM
GGG's Avatar
GGG
well, you can, but I didn't do it (lazy). I didn't remove the upper plenum completely, just push it high enough for me to work on it...but that should give you enouth room to install the spacer.
Old Oct 3, 2005 | 08:34 PM
jwg35c's Avatar
Lazy/smart whatever. Seems like alot of work for no real reason thanks.
Old Oct 3, 2005 | 08:46 PM
GGG's Avatar
GGG
let me know if you have the problem with the bolts that doesn't goes in like me. Thanks. I have 05 6mt btw.
Old Oct 4, 2005 | 11:52 AM
GGG's Avatar
GGG
hmm.. I think I find out where to put those extra two bolts... I forgot to remove the two guide pins that's on the lower plenum.. will try to fix it this weekend.. ARRRRRRR
Old Feb 1, 2006 | 07:00 PM
Simi_G35's Avatar
What kind of gasket/sealant did you use to install the spacer? Did you use the sealant on the top and bottom of the spacer? Would it be better to buy a new gasket at the dealer?
Old Feb 1, 2006 | 07:58 PM
Rickdogg's Avatar
Man, I truly feel sorry for you guys. That is one POS plenum spacer
