z-tube question..
Old Oct 10, 2005 | 12:57 AM
Psycraft's Avatar
z-tube question..
i just installed today my z-tube ans stillen air box!! the sound is amazing!! i have a question,ive seen many warnings reguarding the ac line,i was wondering what i can place on it to protect it..
Old Oct 10, 2005 | 02:16 AM
EricIsKlumzyee's Avatar
if it doesnt rub now it wont rub later.. your z-tube is bolted to the plenum and your air box is bolted to the car
Old Oct 10, 2005 | 12:39 PM
cato's Avatar
SouthernComfort Moderator
I have the same setup...The Z-tube does not allow the AC line to be rubbed. But I went ahead and covered the A/C line with a plastic sleeve. You should have no worries!
Old Oct 10, 2005 | 01:34 PM
Psycraft's Avatar
where did you get the plastic sleeve?
Old Oct 10, 2005 | 02:06 PM
blksnake's Avatar
I used this type on conduit to protect my AC line.
You can find it at any local hardware store.
Old Oct 10, 2005 | 09:11 PM
CarFanatic56's Avatar
did you install the one bottom bolt for the Stillen is supposed to be so hard to install or did you just leave it uninstalled?
btw, can you explain the stillen sound more cuz Im thinking of getting it also....is there that spooling/whistling sound?
Thanks.
Old Oct 10, 2005 | 09:13 PM
Finiti35's Avatar
FGC South Florida BOD
Told ya, glad you like them C.
Which hole did you use for the Stillen box? Post up a pic and we can tell you if it's too close to the AC line.
Old Oct 10, 2005 | 09:35 PM
escobar929's Avatar
i'm assuming he has ur stillen air box, if thats the case he shouldnt have any ac line issues since the hole i drilled keep it bout an inch away
Old Oct 11, 2005 | 02:51 PM
cato's Avatar
That is what I used. I bought it at The Home Depot....
Old Mar 9, 2006 | 09:57 PM
Strtsk8r321's Avatar
Which one's teh AC line? Can I see it w/o removing the ztube?
Old Mar 10, 2006 | 12:31 AM
speedgeek's Avatar
Hope this helps, when i shot my car i figured I'd shoot the ACline for Questions like this
Here's what to cover...
http://www.therightfoot.net/menus/pr.../G35-Main.html
Old Mar 10, 2006 | 12:50 AM
Oh ****. When I bought my popcharger the bracket was missing, so the guy is sending it. For know the ztube and popcharger are resting on that! Is it really fragile?
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
G35-2004-mt6
Sep 11, 2015 04:16 PM
