problems with RPM after installing popcharger and z tube
Old Nov 15, 2005 | 12:35 AM
hondas2kilo's Avatar
Exclamation problems with RPM after installing popcharger and z tube
This happened after i installed the JWT popcharger and Z tube...
Basically what happens is when i'm in any gear, and im driving normally and i feel like accelerating hard, i press the accelerator all the way down, and my RPM jumps a couple thousand, for example, from 2k to 4 or 5k. and then it drops down to about 3k. This is when i'm in a gear. it's not clutch slippage, but it happens when i'm shifting too. When i'm shifiting I can feel the gears engage, but the car doesn't accelerate until it does that little RPM thingy. what is wrong with my car?!
could this be b/c the intake isn't getting enough air? any other possible theories?
help me out...
Old Nov 15, 2005 | 11:46 AM
nas4a's Avatar
I don't see how this could be anything but a drivetrain problem. AFAIK, it's impossible for the car's RPM's to climb with the clutch fully engaged without the car accelerating unless something's slipping.
So either the clutch isn't fully engaged, or it's burned up and slipping. I'm no mechanic, but that'd be my take.
Old Nov 16, 2005 | 02:01 AM
so i should probably get that checked out by the dealer right?
Old Nov 16, 2005 | 03:27 AM
imalazeeass's Avatar
yea but take off ur z tube and pop charger and tell them you've been having this problem since day 1.
Old Nov 16, 2005 | 12:37 PM
SI_G35Coupe's Avatar
i don't think this is intake related as hundreds of members on here are running this setup (myself included).
my car sorta does the same thing, but it's the 5AT that is to blame in my case... in MM mode if i lift off the gas when i shift and then stab it again, sometimes the tranny has to give a 2nd thought to what gear it wants to be in. i agree with nas4a that on a 6mt that is in gear, i don't see how the engine can rev up without corresponding acceleration unless the clutch is slipping
if you wanna remove the popcharger for your trip to the dealer that isn't a big deal. i can't see any dealership, even a very **** one, getting upset about the Z-tube... the thing has a Nissan part number on it
Old Dec 12, 2005 | 10:59 PM
JEVERYDAY's Avatar
wow u guys are scaring me... Now i dont wanna put mine on
Old Dec 13, 2005 | 07:01 PM
GonSpeed's Avatar
is it just the car shifting into a lower gear? every auto will rev up a little before it drops down.
chinee
Jun 10, 2024 07:48 PM
Cskeet
Drivetrain
Dec 3, 2015 09:18 PM
Herbbie Hablib
Forced Induction
Aug 11, 2015 06:22 PM
netcbc
Engine - Intake/Fuel CDN
Jul 24, 2015 02:21 PM
attarday
Jul 15, 2015 04:03 PM
