Engine or Transmission failing
i dont have the numbers of what they should be but i would check to see what others have to see if its correct.
My other suggestion is to do the check on the a/f ratio again. that should be your first step to solving the problem. At least rule out the possibility of what could be the problem.
check the SC belt see if thats fine.
My compression in my engine is ok it was between 200 - 190 in all 6 cylinders. He did indicate though that the engine is misfiring and that the gas is not flowing thru both sides of the engine. There maybe something wrong with the gas lines or the fuel pump, which maybe causing me to lose power.
k67p67
Engine - Power Adders
Aug 29, 2015 08:19 PM
