recommendations for a decently priced inch-lb torque wrench?
I received my MD spacer, but don't own an inch-lb torque wrench. I'd like to do the install myself. Any suggestions on where to buy? Thanks.
not worth it.
you can do the spacer install without the torque wrench. You can estimate it by hand how much you need to do it. There is nothing there that moves that requires precise numbers.
besides most of these torque wrenches are always off.
Originally Posted by myGspot
not worth it.
I tested my Craftsman in/lbs wrench against my Craftsman ft/lb wrench. The 250 in/lb (~21lbs) setting matching the 20 ft/lb setting.
I'm a little confused now. I already own a quality Craftsman foot-lb torque wrench. Is there some kind of conversion table for inches or should I just buy a new wrench?
Using a torque wrench is better than not but keep in mind that the accuracy of these wrenches is highest at thier mid-point (40-60%) setting. If you use a ft-lbs calibrated wrench don't expect accurate in-lb operation in the outer ranges. As with most things - the right tool for the job is what counts. Be careful out there.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
