OEM Used wideband sensors
Old Oct 6, 2010 | 02:21 PM
Andrei's Avatar
The wire harnesses can still be used with cheap $60 sensors. One of them is working but I don't know which one. They are OEM Denso ones. I also marked the boxes to show which one came from which bank. They got a little over 100k miles.
$20 shipped.
Old Nov 1, 2010 | 02:07 AM
Ahmad_1290's Avatar
Are these primary o2's?
Old Nov 1, 2010 | 05:27 AM
Andrei's Avatar
They go into the headers not catalytic converters. Only 04+ Gs have them.
For future reference for anyone, bank 2 is driver side and bank 1 is passenger side. Boxes are marked with D and P but does not matter.
Old Nov 2, 2010 | 12:58 AM
Ahmad_1290's Avatar
I might be interested. Ive got a codes for both my primaries. You know if these will help?
Btw: the car is an 06 Sedan 6MT. Are they the same?
Old Nov 2, 2010 | 01:11 AM
Andrei's Avatar
There is a lot that can cause that and yes they are the same. A vacuum leak, an exhaust leak but only after the headers, a piece of **** faulty fuse, clogged/dirty injectors. You have to check all that stuff. That's why I hate electrical problems but it's very easy to diagnose if you had Consult II like Nissan or Osiris.
Do you get gas smell at wide open throttle? It's a very strong smell. Induces an unpleasant high with headaches.
Old Nov 2, 2010 | 01:21 AM
Ahmad_1290's Avatar
Well I have test pipes, And i always smell gas at every light. And my cars not running like it should be.
Ahmad_1290's Avatar
also I'm right at 50k
Old Nov 2, 2010 | 02:38 PM
Andrei's Avatar
That's probably an intake leak or exhaust leak. You cant have any leak before the test pipes but after test pipe it doesn't matter. Make sure it's gas you smell at stop lights and not exhaust fumes. Exhaust fumes with test pipes smells very different than exhaust fumes with catalytic converters.
Old Nov 2, 2010 | 04:21 PM
Ahmad_1290's Avatar
Aright gotcha. Thanks for the info/help. I've got a buddy that has a scan tool. He's going to check it out for me
Old Nov 10, 2010 | 10:45 PM
SurraTT's Avatar
ill take em for 20 shipped
Old Nov 10, 2010 | 10:51 PM
Ahmad_1290's Avatar
argghh!! YOU BEAT ME TO IT!!
Old Nov 10, 2010 | 10:52 PM
SurraTT's Avatar
lol ill settle for one if you only need one?
since you might be in NC ?? ahaha
Old Nov 10, 2010 | 10:59 PM
Ahmad_1290's Avatar
I need bank 1 sensor 1. Thing is.. Andrei said he doesn't know what one is good. And yea im in NC
Old Nov 10, 2010 | 11:12 PM
SurraTT's Avatar
ohh ok i see, i just need a wb that reads correct AFR idc if it throws a code im working on ecu swap stuff, i have one bran new oem wb but need another and dont want to for $100 for experimental stuff.
you can have them if you want. I def dont need them anytime soon, and might even be better off with a new one without the plug anyway.
Old Nov 11, 2010 | 01:41 AM
Ahmad_1290's Avatar
Gotcha. Thanks bro. Well I guess I'll take em. I'm paypal ready. PM me where you'd like the money
