WTB: YAW/Gravity Sensor - 2005 G35 Coupe 6-Speed
Old Oct 22, 2011 | 03:38 PM
brn2drive's Avatar
Like the title says, I need the Yaw Rate Sensor, also know as the gravity sensor for my 2005 G35 coupe.
Thanks!
Old Oct 23, 2011 | 09:57 AM
alxmlr789's Avatar
Just wondering, how do you know that this went bad in your car? Im having issues when i take a real hard right turn (on an exit ramp or similar) and my VDC kicks in when it seems like it really shouldnt be. lol Sorry for the thread jack.
Old Oct 23, 2011 | 12:02 PM
alfhasg35's Avatar
I always thought the vdc kicks in waaaaay before it's suppose to also.. That's why I always turn it off..
As for the yaw rate sensor...? I just had to replace mine on my 4runner.. It was a lil pricey cuz the stealership raped me raw dawg...!
Old Oct 23, 2011 | 03:49 PM
brn2drive's Avatar
No problem! My low traction and VDC OFF lights are both on all the time. I originally thought I needed new brakes but the dealer scanned and told me my YAW sensor went bad. It's pretty easy to replace but not a cheap part. So hopefully i'll find a used one.
How are your tires looking? Might be that your rears are getting low and slipping, just a small slip will cause VDC to jump in.
Old Nov 19, 2011 | 07:49 PM
Z1Motorsports's Avatar
We have a used one on the self, I would have to check on pricing, and I will sell it to you if you insist but i'm 99% sure that isn't the problem. For some reason the dealer likes to blame VDC problems they can't figure out on the YAW Sensor, I had the same issue (hints why we have one on the shelf) it didn't fix my problem. We have also seen this a handful of times since. A bad wheel bearing will cause the VDC to do crazy things at low speeds, if you have someone local that has Cipher they can log your wheel speed sensors and tell you which bearing it is.
Let me know if I can help you with anything!
-Rob
Old Feb 27, 2012 | 05:01 PM
YoTimesUp's Avatar
Rob knows what he is talking about I'd try it his way first.
~ Michael
laksjd84
Feb 28, 2026 01:58 PM
mike730
Jan 12, 2018 04:25 PM
Blakelyg35
Aug 15, 2015 12:12 PM
AustinErkl
Drivetrain
Jul 18, 2015 05:44 PM
Scredeur4
Steering & Suspension
Jul 17, 2015 06:30 AM
