FS: Cobb Accessport (03-06 Coupes/04.5-06 Sedans)
Old May 23, 2013 | 08:27 AM
JaE35's Avatar
Moderator
G35 Sedan
Supported years in title, I purchased this but my sedan is too old Super easy to use, check the tunes available from link below.
http://accessecu.com/accessport/infiniti/G-Series.html
Basically NIB, get sign pic up after work. Model AP-NIS-002
300 shipped
Old May 23, 2013 | 06:35 PM
G35BAW's Avatar
Nice
Will this work with 5at trans
Old May 23, 2013 | 06:37 PM
JaE35's Avatar
Moderator
G35 Sedan
Click this link and check out the tunes in the list
You'll see tunes for 6MT and 5AT
Old May 24, 2013 | 10:29 AM
JaE35's Avatar
Moderator
G35 Sedan
Still got this..well i think lol, local might pick it up
Old May 26, 2013 | 10:49 AM
JaE35's Avatar
Moderator
G35 Sedan
THIS IS NOT A PIGGYBACK PEOPLE..adding more details
The "mapping" of the AccessPort will also increase boost, remove the speed limiter, and make instant performance results you can feel! Also Allows you to check and clear Check engine Codes on your own.
The AccessPORT is the most user friendly reprogramming device for your vehicle's computer! The provided mapping will optimize the air/fuel ratio and ignition timing, remove the speed limiter, and more for performance results you can instantly feel! But the AccessPORT is so much MORE than just a REFLASH DEVICE. It allows you to monitor your Fuel Economy (average and real time), perform performance tests in order to estimate your 0-60mph and 1/4 mile time, read and decifer ECU trouble codes (CELs), and monitor live data via the OEM vehicle sensors which eliminates the need for costly and cluttering aftermarket gauges!
* Improve horsepower, torque, and fuel economy at the touch of a button
Display vehicle data such as RPM, temperatures and more while you drive
Easy installation, no mechanical or computer skills necessary
Connects to your vehicle via the OBD-II port conveniently located under your dash
Exclusive ability to switch between different 'modes' on the fly
Pre-calibrated to maximize performance of stock or modified vehicles
Easy-to-read color display
Update over the Internet to stay up-to-date with the latest features
Read engine trouble codes (DTC) yourself, eliminating trips to the dealership
Not a "piggyback" - once vehicle's computer has been programmed by the AccessPORT, it can be removed and the settings will stay on your computer.
Not just an "ECU reflash" - AccessPORT features enhancements such as on-the-fly mode switching, data monitors, reading DTCs, performance monitors and more.
Old May 27, 2013 | 12:12 PM
JaE35's Avatar
Moderator
G35 Sedan
bump 300 shipped
Jusseth
Sep 13, 2020 12:25 PM
G35Papa
Engine - Exhaust
Aug 18, 2015 11:39 AM
yoyoyo8
Aug 12, 2015 03:04 AM
yassy
Aug 11, 2015 09:31 PM
LoSt180
Steering & Suspension
Jul 15, 2015 08:31 AM
