FS: Brand New HALTECH Plug & Play with Dual Wideband & Air Temp Sensor
Old Nov 20, 2015 | 11:44 AM
the3kgt2's Avatar
Brand New HALTECH Plug & Play ECU Standalone Engine Management System
I am selling a brand new Haltech Platinum Pro Plug and Play ECU Engine Management System. I purchased this brand new from Z Car Garage but I have since decided to sell the car before getting a chance to install it. My loss is your gain.
Price is $1,700 shipped
HT-055016 Platinum PRO Plug-in Nissan Z33 350Z DBW Kit
High Performance Fuel and Ignition ECU for Nissan 350Z.
Fully programmable ECU interfacing directly with all the standard Nissan sensors and on board computer systems. Taking control of all the essential engine management tasks such as fuel delivery, ignition timing, boost levels, camshaft positioning and correction maps, the Platinum Pro Plug-in 350Z (Z33) ECU even interfaces with the factory Nissan CAN bus for on-board diagnostics and troubleshooting.
Features:
• Sequential Fuel Control
• Direct Fire Ignition Control
• Variable Camshaft postion mapping
• Knock Detection
• Engine Rev Limiter
• Closed loop boost control
• Launch control
• Closed loop wideband 02 control
• On board data logging
• Speed density, Alpha-N or MAF tuning
• Additional user definable inputs and outputs
• Windows Software
The Platinum Pro Plug-in 350Z (Z33) kit includes:
ECU Programmable Computer,Plug and Play wiring Harness,USB Programming Cable,Instruction Manual (on CD), Programming software
Main Features over previous model
• Fully Stand Alone – No factory ECU Required – Controls all factory Functions
• Complete Electronic Throttle Control
• Generic CAN OBDII Support
• CAN Bus Intergration – Haltech Communicates with the Instrument Cluster, ABS & PDM.
• Crusie Control
• Flex Fuel / E85 Ethanol Support
• Long Term Fuel Trims
• Knock Control with Long Term Trims
• Auxillary Inputs and Outputs
True Stand Alone
• New ECU is a complete stand alone.
• The OEM ECU is not required at all as the Haltech ECU takes control of all functions, unlike any other tuning solution.
• No more check engine lights, idle problems, torque limits or rev limiters.
• The Haltech allows full control over the engine, without complications or compromise.
More Inputs and Outputs
• Not only does the Haltech Pro Plugin utilise all the factory inputs and outputs, but it also has auxiliary Inputs and Outputs.
• These auxiliary pins allow greater functionality, such as boost control, water injection and even Flex Fuel E85 support.
• If further functions are required, multiple CAN Expansion Devices can be connected to the Haltech.
More Control
• The Haltech Pro Plugin has more than double the correction tables available than the previous ECU, with higher resolution and more flexibility
• Electronic Throttle control allows the user to define Pedal vs Throttle position as well as user definable Idle Control
• Multiple user generic correction tables for Fuel, Ignition and Boost control.
More Functions
• Extra Functions such as Boost Control, Launch Control, Antilag, Speed Limiter, Nitrous Control are all standard.
Operating Temperature Range:
-40Deg C to 85 Deg C ( -40 Deg F to 185 Deg F)
Models covered:
Nissan 350Z Z33 – (2003 -2006)
Nissan Skyline V35 – (2003 -2006)
Infinity G35 – (2003 – 2006)
Engine Codes: VQ35DE inc RevUp – (Single Throttle Only – Does not suit VQ35HR)
Transmission: Manual Only
EDIT: Dual Channel Wideband Kit and Air Temp Sensor are sold.
Attached Thumbnails Brand New HALTECH Plug & Play with Dual Wideband & Air Temp Sensor-20151120_081848.jpg
Last edited by the3kgt2; Mar 5, 2016 at 10:50 AM. Reason: EDIT: Dual Channel Wideband Kit and Air Temp Sensor are sold.
Old Dec 6, 2015 | 07:51 PM
the3kgt2's Avatar
Price drop!
Wideband and Air Temp sensors are sold.
Standalone Haltech still for sale!
Old Mar 5, 2016 | 10:50 AM
the3kgt2's Avatar
Price drop!
Old Mar 7, 2016 | 06:53 PM
philthethrilloh's Avatar
awesome , glws
Old Mar 16, 2016 | 05:05 PM
mattesatinblack's Avatar
Still got i am intrested
Old Mar 17, 2016 | 06:26 PM
Moncef's Avatar
I'd like to purchase this today. send me a message at 319.899.9763. Thanks.
Old Mar 27, 2016 | 06:33 PM
the3kgt2's Avatar
Sold
