FS: Okay Projects Plasma Coilpacks
Old Sep 30, 2017 | 05:34 AM
DrivenG's Avatar
Whats up everyone, parting out what was going into my twin turbo build as I bought a house recently and need to clear some funds.
This is a full set (6) Okada Projects Plasma Coils. If you don't know what these do here is a quick run down from their site.
A revolution in ignition technology!! The Plasma Direct is the ignition coil with a high power amplifier built in to it. The Plasma Directs produce 4 times more spark energy than stock coils and also generate an ultra fast multi spark discharge of 10 sparks up to highest RPM. The spark amperage is increased 100%, allowing the spark to reach many more molecules and therefore accelerate the ignition and combustion process. This is extremely important in forced induction applications but also improves the performance of normally aspirated engines.
The Plasma Direct will increase horsepower and torque throughout the entire rpm range. This upgrade will also reduce fuel consumption. Even the engines with a legendary smoothness will be further refined with the Plasma Direct upgrade. Our Plasma Directs are OBD II compliant and C.A.R.B. approved.
Highlights:
-100% secondary current (Spark Amperage) increase
-4 Times Spark Energy Increase for the initial spark discharge
-Easy installation. Only replace stock coils to Plasma Direct.
-Compatible with all OEM components
-Compatible with OBD-II (On-Board-Diagnostics)
Fits: Nissan 350Z V6 3.5L Z33, HZ33 VQ35DE 02-06
Anyway I'm looking for $850 shipped
only used them briefly on my vortech build less than 4k miles. open to offers but be reasonable these are $1300 coil packs and thats not including the spark plug boots this is plug and play!!!
Attached Thumbnails Okay Projects Plasma Coilpacks-7a7609a6-afbd-426a-aa55-e9306f6f5c71.jpg   Okay Projects Plasma Coilpacks-82831b95-e774-4d8d-a73c-29c92811b906.jpg   Okay Projects Plasma Coilpacks-493ae863-fbfb-449f-9ecb-6f2c9bad8f37.jpg
Old Oct 4, 2017 | 12:47 AM
DrivenG's Avatar
Solddddd
