FS[NorEast]: Invidia Gemini True Dual w/ Rolled Burn Tips
no it does not. it's made for a g35. if you cut the pipes, yes it would fit. but there are no extensions that you can simply remove.
I believe yes, but you will need to have the tips extended to the end of the bumper. I'm basing that on this thread where he had a coupe exhaust on an FX and the only mods are for the tips.
these tips can be brought out quite a ways, i don't know if they will be out far enough for a FX35, but you can always try, if not, go to a welder. Shouldn't be that expensive, they don't have to actually cut anything off since these tips are removable, they'd just have to weld on new ones, if need be.
FX35:
http://www.invidiaperformanceparts.c...2190&year=2003
G35:
http://www.invidiaperformanceparts.c...?gfid=p75-c260
If you scroll down and look at the applications, they're all the same. You should be fine with my tips too.
04G35NYC
2nd Gen (V36) Sedan
Sep 13, 2015 02:56 PM
