FS: HR Y-pipe from 2008 G35 sedan
Old Feb 25, 2013 | 09:58 PM
bsowhat1's Avatar
************SOLD************
I am selling the HR Y pipe from my previous 2008 G35 sedan. The flanges are rusty but I will clean them up. Otherwise all the heat shields, flex pipes, and vibration dampers, are intact. $40.
Old Feb 26, 2013 | 10:29 AM
bsowhat1's Avatar
FYI the 07-08 G35 sedan HR Y-pipe is not quite the same as the 07-08 350z pipe. However, if you are installing this with the stock G35 exhaust, the midpipe outlet will match up better since it measures 2.25" I.D. The cat inlets measure 2-1/16" I.D. (just like the 350Z HR Y-pipe).
Old Feb 26, 2013 | 11:14 PM
Frankieg35's Avatar
Is this the same measurements for the g35 coupe??
Old Feb 26, 2013 | 11:38 PM
bsowhat1's Avatar
Stock cat outlet is 2". Not sure about the stock mid pipe since I don't have mine anymore. So the HR Y pipe matches the stock cats at least.
Old Feb 27, 2013 | 01:02 AM
Frankieg35's Avatar
The coupe midpipe is 2.5.. so I would need the y pipe from the hr350z with 2.5 y pipe??
Old Feb 27, 2013 | 08:14 AM
bsowhat1's Avatar
Where are you measuring 2.5"? Inner or outer diameter? My measurements above are inner diameter. The 350z HR Y-pipe is supposedly 2.45" inner diameter at the midpipe outlet.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
crazy_g35s
Jul 20, 2015 02:30 PM
newbdriver01
Jul 15, 2015 06:10 PM
