Polished APS Tallboy Plenum
Old Nov 22, 2011 | 07:42 PM
SG Blaze's Avatar
Arrow Polished APS Tallboy Plenum
$480
Old Nov 22, 2011 | 07:46 PM
Beebo's Avatar
damn thats a good deal... what are the power gains with the plenum?
Old Nov 22, 2011 | 07:49 PM
SG Blaze's Avatar
never got around to putting my car on a dyno, but it sure felt faster and not too mention louder with a nice growl.
Old Nov 22, 2011 | 11:29 PM
Tslider's Avatar
I haven't done much research into these, I assume that you no longer can/should run a plenum spacer with this piece?
Old Nov 22, 2011 | 11:33 PM
SG Blaze's Avatar
That is correct, you cannot use this plenum in combination with a spacer. From what I understand the gains are better then the spacer.
Old Nov 25, 2011 | 03:48 PM
SG Blaze's Avatar
Bump
Old Nov 25, 2011 | 03:56 PM
CandlestickPark's Avatar
ill Sedan
Please post a pic with the handwritten note and the APS plenum in the same photo. Thanks.
I love my APS plenum. The gains on this should be slightly better than an 1/2" spacer.
Old Nov 25, 2011 | 03:57 PM
SG Blaze's Avatar
I'll go snap a pic for ya
Old Nov 25, 2011 | 04:01 PM
SG Blaze's Avatar
Old Nov 27, 2011 | 05:08 PM
SG Blaze's Avatar
Bump
Old Nov 27, 2011 | 09:37 PM
G35_Brian's Avatar
if you have this in a couple weeks ill scoop it up from you and im local as well.
Old Nov 27, 2011 | 10:21 PM
SG Blaze's Avatar
Sounds Good
Old Nov 29, 2011 | 04:05 PM
SG Blaze's Avatar
Bump
Old Nov 30, 2011 | 02:34 AM
josh.irvine.6's Avatar
Just to clarify.. You're selling both the Polished APS plenum AND the carbon engine cover for 480?
Old Nov 30, 2011 | 12:42 PM
SG Blaze's Avatar
APS Plenum: $480
Comes with all necessary parts to run a throttle body coolant bypass as well.
Carbon Fiber Engine Cover: $100
