FS: Rc engineering nissan 350z/g35 saturated injectors(440cc)
Old Dec 31, 2020 | 07:34 PM
g35life's Avatar
makowskib@gmail.com
Asking total $300USD. Will ship worldwide. RC Engineering has been providing high performance fuel injectors for the race industry for over 30 years. RC Engineering is known worldwide for its high performance high flow electronic fuel injectors. RC injectors are available for a wide range of automotive, motorcycle and marine engines used in high-performance or racing applications. Bosch, Denso and Honda style tops available.
RC fuel injectors come is a variety of sizes for naturally aspirated vehicles to full race turbo applications. They are offered in high resistance saturated or low resistance peak and hold setup. Each RC injector is flow tested to insure proper flow before it is shipped. Each set ordered will include data results from each flow test. RC Engineering fuel injectors come with a one year limited manufacturer warranty.
Flow Rate - CC's: 440 CC's / MIN @ 43.5 PSI
Flow Rate - LB's: 42 LBS / HR @ 43.5 PSI
Resistance: 12.5 Ohms @ 68 F
Voltage: 8-15 Volts, nominal 13.5 Volts
Amperage: 1.0 Amps
Pressure: Min 30 PSIG / Max 100 PSIG
DETAILS SKU:SLG-0440-VQ35 Stock #:SLG-0440-VQ35
b2autodesigns
Engine-Vendor
279
Feb 16, 2017 11:42 AM
Ray@OCInfiniti
Engine - Intake/Fuel
Aug 29, 2011 04:42 AM
GT-ER
Oct 29, 2010 12:08 AM
Larry@Showtime
Engine-Vendor
Aug 17, 2009 09:22 AM
