FS: Turbonetics Turbo Charger Kit
This kit has been used but only for under 2000 miles! Practically new at over $3000 of the actual cost of the kit and the Reflash! If the kit is missing anything at all, feel free to contact me with the phone number I will provide after the finalization of the sale! The kit was modified for a 2006 G35 automatic transmission and the only pipe that was affected was the crossover pipe.
If you need a manual pipe, Turbonetics sells the Manual pipe for about $250 shipped. The injectors are a bit bigger than the kit description but still work great! Awesome sound when you hit 3000+RPM with alot of torque! It also has a 9lb. 9LB is 8PSI! Happy bidding and I will answer any questions as well!
THIS KIT IS COMPATIBLE WITH 2003-2006 G35's AND 2003-2005 350Z's WITH 3.5L ENGINE. CHECK TURBO-KITS.COM FOR FULL FITMENT INFO!
SOME NICKS AND SCRATCHES BUT THE VISIBLE SIDE IS 95% FLAWLESS!
COMES WITH BASE MAP FOR 8PSI WHICH IS A WHOPPING 358.8WHP AND COST $1000 TO TUNE IT!! I NEED TO KNOW YOUR MAKE AND MODEL AND ENGINE SERIALS IN ORDER TO MODIFY IT TO WORK WITH YOUR ECU! I STILL RECOMMEND DYNO TO GET BEST PERFORMANCE!
WITH THE FLASH I PROVIDE, I AM ALSO PROVIDING A FULL OSIRUS LICENSE WHICH COSTS $700 AND GIVES YOU FULL CONTROL OVER YOUR OWN TUNE OR TO CHANGE YOUR TUNE LATER ON! GREAT SYSTEM WITH REVUP! ONCE AGAIN, CHECK COMPATIBILITY WITH THE REV UP SOFTWARE WITH YOUR ECU!! THIS WASN'T INCLUDED IN THE KIT PRICE OF $5295.
If you need a manual pipe, Turbonetics sells the Manual pipe for about $250 shipped. The injectors are a bit bigger to the kit description but still work great! Nice Turbo sound when you hit 3000+RPM with alot of torque! It also has a 9lb. 9LB is 8PSI! Happy bidding and I will answer any questions as well!
G35 Coupe Turbo Kits Include:
-Turbonetics T-60-1 Turbo
-Polished Mandrel-Bent Exhaust Pipe
-2.5" Stainless Mandrel-Bent Downpipe
-Turbonetics Evolution 35mm Wastegate
-Front-Mount Intercooler
-Dual Fan Intercooler Shroud
-Turbonetics Raptor Blow Off Valve
-AEM Dry Flow Air Filter
-Mandrel Bent Aluminum Piping
-(6) 600cc Injectors
- Walbro 255LPH Fuel Pump w/ Install Kit
-Turbonetics Full ECU Reflash
-Oil Feed & Drain Line Kit
-Install Instructions & Wiring Diagrams
-All Necessary Hardware & Fittings
I am trying to get the water line feed kit for the turbo as well because it is incredibly useful to run the water to cool the turbo!
Contact me @ roy.testerman@gmail.com if interested and if you are in the maryland area, feel free to come view the kit and I can refer you to a great installer that is really good with everything and he has my tune as well to modify!
These are pictures of the Intercooler with fans, The Turbocharger and some of the pipes for the kit. One of the pipes have scratches (yellow circle) and a knick while the other pipe has small dents (pink circle) which neither pipes are affected from their intended operation. All of the visible parts are unscathed and look fantastic.
More pictures of the kit.. Some more of the pipes in pristine condition as well as the ac line, turbo heat shield, 600cc injectors look perfect, the fittings for the kit and last but not least, the Osirus Uprev cable for flashing with license on board($700) which is a full issue to use the software by the user and customize your own tune if you know what to do. As I said, I will do my best to provide my tune as long as you give me your car engine and model number so I can get my mechanic to take care of it.
And here are more...Last but not least! Some more assembly parts ie. nuts, bolts etc and etc... the air intake and the 9lb boost wastegate spring. I want to try and find the other 2 springs but it may not be possible... Hate to see my baby go but I want to go to the visuals of my G now!
Geat deal. I just bought exhaust and brakes and wish I have money for this. If you have till have this in a few months, I would have to buy it. GWLS!!!
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
boostelevator
Engine - Power Adders
Sep 9, 2015 05:56 PM
. Just needed to get it out of my house because I was about to put it back on my G!
