Engine-Vendor Includes cams, clutches, flywheels and all other power related components.
HKS Twin Power DLI II
Old May 11, 2007 | 08:35 PM
InZomniac's Avatar
HKS Twin Power DLI II Ignition Amplifier 350Z/ G35
The Twin Power ignition amplifier incorporates both the CDI and transistor method ignition to provide optimum spark duration and maximum voltage output, resulting in crisper throttle response and a smoother engine powerband. The CDI method, capacity discharge ignition, provides maximum voltage by transferring all stored energy in the capacitor to the ignition coil so that the ignition current can buildup quickly, thus making the Twin Power very effective in the higher revs where a normal spark would tend to diminish. This strong rapid spark prevents the high rpm ignition miss that reduces peak power. The transistorized method generates high voltage by using transistors to cut off current to the coil, thus allowing for a long energy discharge. This longer spark duration allows the Twin Power to improve lower RPM throttle response and torque. The combination of the CDI and the transistor method incorporates two distinct systems into one high performance unit, hence the designation of Twin Power. The Twin Power produces a spark output that is typically 1.5-2.5 stronger than of the stock ignition system and consumes about 35% less power input than other ignition amplifiers. Each compact and attractive Twin power unit is constructed of durable anodized aluminum and sealed to prevent corrosion from moisture. General wiring harnesses are included in each unit to aid in installation and mounting. Vehicle Specific wiring harnesses are also available for certain models to further aid in installations that require intricate integration.(CARB E.O. # D-186-22)
I have a group buy going on with HKS that allows me to sell these for... $430 plus shipping!
Old May 16, 2007 | 12:29 AM
GTT's Avatar
GTT
G35 Twin Turbo
where do you install it ? here is a picture if you guys wanna see it !
Old May 17, 2007 | 02:05 PM
InZomniac's Avatar
Anywhere in the engine bay would work fine.
g.spot
May 9, 2016 10:54 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
Red G Coupe
Video Share
Sep 6, 2015 06:45 PM
