Engine-Vendor Includes cams, clutches, flywheels and all other power related components.
Greddy TT+IC Kit $5549 Shipped!<BC Cam+VSR $1150!<HKS HiperTi+Helix TP $1499 Shipped!
Old Sep 14, 2007 | 04:35 PM
gruppe-s's Avatar
Former Sponsor
We are not just retailers, we speak from experience. Built in house by Design Craft Fabrications in conjunction with Falken and Dynamic Autosports, the Falken G35 was a great test bed for motor builds, turbo setups, and cooling for the VQ35DE. If you would like more info on our company... http://www.gruppe-s.com/Contact/about_us.htm
(Pictures courtesy of Super Street Magazine)
Want to be like the Falken G35?
Greddy Twin Turbo Kit w/ Intercooler Kit
-Twin TD05H-18G Turbochargers
-Dual Exhaust Manifolds
-Dual External Wastegates
-Greddy Intercooler for Twin Turbo Kit
-440cc Injectors
-E-Manage Piggyback Computer w/ wiring Harness
-Greddy Air Filters
-New Radiator Overflow Tank
-Oil Pan, Oil Feed Lines, and Oil Return Pipe
-All brackets, gaskets, fittings, couplers, heat wrap, zip ties and vacuum lines supplied
$5549 Shipped!!
NO Cooling issues with the Falken G35 with the Koyo unit.
Koyo Radiator + Samco Hose Kit
-Full Aluminum 2 Row Radiator
-36mm core for good cooling on the street or track
-OEM Fitment
-Durable, Heat Resitant Silicone Hose
-Handles very high pressure, nice dress up piece
$469 Shipped!!
The Falken G35 made really good power with these, but they will work even for the all motor guys out there!
Brian Crower Valvesprings/Retainers + Stage II Cams!!
-Designed for high rpm
-Chrome Silicone Alloy Springs
-1.425" @ 80 lbs / Open: 0.990" @ 192 lbs / Coil Bind: 0.900"
-No Machine Work Required
-264 degree duration
-10.84mm lift
-Cams will work with stock Valvesprings, but its a nice upgrade at the same time
$1150 Shipped!!
For the guys that want to get a little crazier!
Brian Crower Stroker Kit VQ35DE 4.15L
-Available in any desired bore and compression ratio for use in turbo or normally aspirated.
-BC 4340 billet steel crank (88 or 86.4mm stroke). Avail. balanced or self-balanced.
-BC 4340 Pro Series steel billet connecting rods w/ARP 220,000 psi fasteners.(Rated to 1200+ HP)
-CP aluminum forged pistons (Any bore size, any compression ratio).
-9310 nickel carbon steel alloy wrist pins available as a standard feature.
-Ductile iron plasma top rings, tapered second ring, low tension oil rings.
-Req. block clearancing & removing piston squirters. Plugs incl.
-Kits are available fully balanced ready to install or unbalanced.
-ACL Race Bearings sold seperately.
$4599 Shipped!!
HELIX V2 CATDELETE Test Pipes
-Big HP Gains with test pipes
-V2 design eliminates cracking / stress on exhaust system
-Make your exhaust system sound more aggressive!
$125 Shipped
COMBOS:
HKS Hiper Ti Cat-Back Exhaust & Helix V2 Test Pipes
-Full Dual Exhaust
-Polished SUS304 Stainless Steel w/ Adjustable Dual Titanium Tips
-H Pipe Included
$1499 Shipped!
Greddy EVO 2 Exhaust & Helix V2 Test pipes
-Twin muffler system
-95 decibel ok
-Solid performance gains
$949 Shipped!!
Fujitsubo Legalis R & Helix V2 Test Pipes
-95 decibel ok
-Single cannister system
-Quiet system
$899 Shipped!! Add Fujitsubo Y-Pipe for $400
Call in or use paypal to order today!!
Thanks,
Gruppe-S Engineering
20521 Teresita Way
Lake Forest, CA 92630
Paypal: payments@gruppe-s.com
Old Sep 21, 2007 | 03:04 PM
gruppe-s's Avatar
Former Sponsor
bump!
Old Sep 23, 2007 | 01:54 PM
AS007's Avatar
Are there any cams that will work with a revup motor? 2005 sedan 6mt......
Old Sep 24, 2007 | 02:14 PM
gruppe-s's Avatar
Former Sponsor
We will be offering the Brian Crower Revup cams as soon as they are available.
Thanks,
Gruppe-S
Old Oct 17, 2007 | 10:02 PM
gruppe-s's Avatar
Former Sponsor
Bump Guys
Gruppe-S
Old Oct 24, 2007 | 08:49 PM
gruppe-s's Avatar
Former Sponsor
Bump!
Old Nov 8, 2007 | 09:32 PM
gruppe-s's Avatar
Former Sponsor
That would be $1325 shipped for the fmic alone.
Kyong
Old Nov 12, 2007 | 02:38 AM
GbyRd35's Avatar
how much shipped to houston tx and dooes the turbo spool fastenou that you wont have to power brak the turbo(i really dont remember what its called thats why i call it "power braking"
Old Nov 12, 2007 | 03:17 PM
NETSHARK's Avatar
its called Brake Boost
Old Nov 12, 2007 | 04:35 PM
Pska's Avatar
do you guys do gruppe buys?
hehe
Old Nov 13, 2007 | 01:52 PM
gruppe-s's Avatar
Former Sponsor
gbyrd35 turbo kit is $5549 shipped. twin 18g turbos, they do spool pretty quick, plenty of guys out there making 400 whp on 7lbs.
PSKA we do gruppe buys, but depends on the item, pm me if you want info on a particular item.
Old Nov 30, 2007 | 12:11 PM
gdfvme's Avatar
can you provide dyno papers to show whp on the engines you build
Old Nov 30, 2007 | 03:04 PM
gruppe-s's Avatar
Former Sponsor
The only VQ built here is the Falken G35, we aren't allowed to disclose the Dyno sheet on that one. We are currently in works of building our own 350z for Drift, I will post up numbers on this one when we finish.
Thanks,
Kyong
Old Nov 30, 2007 | 04:25 PM
usingthejohn's Avatar
how much for the TT kit, FMIC and Radiator to 90621
Old Dec 26, 2007 | 08:46 PM
gruppe-s's Avatar
Former Sponsor
PM Sent
