Engine-Vendor Includes cams, clutches, flywheels and all other power related components.
Brian Crower Engine components!!
Old Feb 17, 2008 | 07:44 PM
Julian's Avatar
MRC Motorsports will now be offering Brian Crower producst for the VQ35DE.
Products range from cams, to a full stroker kit, and are compeditively priced!
Stroker Kits
BC 4340 billet steel crankshaft (88mm or 86.4mm stroke).
BC 4340 Pro Series steel billet connecting rods w/ARP 220,000 psi fasteners.
CP aluminum forged pistons (any bore size, any compression ratio).
9310 nickel carbon steel alloy wrist pins.
Ductile iron plasma top rings, tapered second ring, low tension oil rings.
Typically includes aluminum buttons/rail supports (not locks).
Requires balancing. 88mm stroke requires block clearancing.
CAMS
High Performance/Race
Plug and play application. Short duration for nice street manners, slight lope at idle. Excellent all purpose spec. OEM spring OK.
264°/264° 222°/222° .426"/.426" 10.82/10.82
VALVE SPRING/RETAINER KIT
Designed for high rpm, BC valve springs are wound from only the highest grade, super clean, chrome silicone alloy and feature proprietary processing procedures for consistent pressures. BC titanium retainers are CNC machined from 6AL4V round bar titanium to exacting tolerance
STAINLESS STEEL VALVES
BC valves are made from premium stainless steel, fully machined and swirl polished for ultimate air flow. Dished head for added weight savings and increased valve control at high rpm. Standard and oversize head.
We also just took delivery of the Stage 3 cams!!
Here are the cam specs.
Stage 3 on left 2 on right.
Old Feb 17, 2008 | 08:22 PM
GrayG35's Avatar
pm me prices on both stage 2 and 3 cams shipped to 78251. thanks
Old Feb 17, 2008 | 08:31 PM
g35man04's Avatar
CLUB MODERATOR
pm price shipped on stage 3 cams, stainless steel valves, valvesprings and retainers.
Old Feb 17, 2008 | 09:00 PM
Julian's Avatar
Stage 2 $850 shipped Stage 3 $945 shipped
Freeman186
Sep 6, 2023 10:07 AM
magnetism80
Feb 1, 2019 10:00 AM
Joe Gargano
Sep 18, 2015 11:17 AM
HellaG35
Intake & Exhaust
Sep 8, 2015 10:02 PM
Jnm07
Sep 5, 2015 01:16 AM
