****Fidanza Sale!****Lightweight Flywheels and Performance Clutch Kits****
For sale is Fidanza Lightweight Flywheel!!
ALUMINUM FLYWHEEL
Our aluminum flywheels are made from the highest quality 6061 T6 aluminum. The material is fantastic for strength, heat dissipation and of course reduction in weight. The friction surface we use is an icredibly strong 1045 steel. The flywheel friction plates are milled to meet our high specifications. A Fidanza aluminum flywheel can mate with any type of clutch material, including organic, kevlar, ceramic, metallic and sintered iron. We attach the replaceable friction surface with military grade aerospace fasteners. With these replaceable friction plates there is no need to replace the entire flywheel when the clutch or flywheel is at the end of it's life, saving time and money. The ring gears we use are also made from 1050 steel and are heat treated for durability. The flywheel ring gears are heated then pressed on and secured with grade 8 button screws. We were the first to utilize a stepped dowel system in most of our flywheel applications. This doweling method ensures that once the pressure plate is installed the dowels cannot be removed because they become locked into place.
No chromemoly can compete with the awesome serviceablity, strength and superior design of Fidanza's aluminum flywheels. If there was a better material out there, we would be using it.
These retail for $726.96!!! Get them here for only $559.99!!
Fidanza Performance Clutch Kit:
3.2 Performance Clutch
Like our lightweight flywheels we choose to use the very best in materials. That’s why we designed our Three Point Two with the Kevlar buttons. With 100% Kevlar friction you get more grip and more life than the Two Point One. However, since it has no marcel (cushion) this disc sacrifices a little bit of its smooth engagement. Still, this disc can be installed on a daily driver. Just behave and be patient during it’s 500 mile break-in period. Once that’s over you can be as nasty as you want.
Retail for this is $862.16!! Get it here for only $659.99!!
Feel free to PM me with any questions!
ALUMINUM FLYWHEEL
