Engine-Vendor Includes cams, clutches, flywheels and all other power related components.
All Engine Parts on Sale- All Competitors Beat on AEm and Injen- In Stock!!!
Old Feb 25, 2008 | 09:22 PM
gruppe-s's Avatar
Former Sponsor
AEM
Manufactured and assembled in the USA. AEM high flowing filter and cold air extension enables an increase of 7-10HP to the wheels. 50 State Legal and C.A.R.B. approved.
Available in: blue, red, and polished
CAI
03-05 VQ35
$245 Shipped
06-07 VQ35HR (Dual Intake)
$375 Shipped
Injen
The Injen Technology cold air intake system is a high-performance, dyno-proven system made of CNC mandrel bent 6061 T-6 aluminum alloy. Each Injen cold air intake is carefully engineered for a perfect fit and superior performance. Many other Injen Cold Air Intakes are made of only 3.00" diameter tubes. This may cause friction between the battery and the intake system, dented hoods and an unbalanced air fuel ratio which can be harmful to your engine.
CAI
03-05 VQ35
$245 Shipped
Injen Exhaust
G35 cat-back w/ H-pipe and 4 1/2'' straight tips
$789 Shipped
G35 60mm cat-back w/ H-pipe and 4 1/2'' Titanium tips
$875 Shipped
Skunk2 Plenum Carbon Composite Spacer
This spacer is dyno proven to outperform aftermarket manifold plenums currently being sold. The skunk2 spacer effectively increases plenum volume, lowers intake air temperatures, and allows front cylinders to breath more efficiently resulting in gains of up to 10+ hp to the wheels, and increased throttle response.
03-05 350Z/ G35
$175 Shipped
Brian Crower
The 3.5L (3498 cc) VQ35DE is used in many modern Nissan vehicles, but the most popular US chassis for engine upgrades are the Nissan 350z and the Infiniti G35. Unlike the inline six cylinders (RB26, 2JZ), the VQ35DE is a V6 configuration. It adds variable valve timing and has a stock bore of 95.5 mm and stroke of 81.4 mm. Output ranges from 240 hp to 301 hp (179 to 225 kW) and 246 ft·lbf to 287 ft·lbf (334 to 390 Nm). The VQ35DE is built in Iwaki, Japan and Decherd, TN. It was on the Ward's 10 Best Engines list for 2002 through 2006, the only engine to be on Ward's list every year since it's inception. The VQ35DE has an aluminum engine block and aluminum DOHC cylinder heads. It uses SFI fuel injection, has 4 valves per cylinder with VVT and features Nissan's nylon intake manifold technology. A modified version of the VQ35DE, called the S1 is produced by Nismo for the Fairlady Z S-Tune GT. It produces 300 ps or 285 hp (220 kW) at 7200 rpm, a higher rev-limit than that of the original VQ35DE.
Stage 2 Camshafts
$899 Shipped
Valve Spring/ Retainer Kit
$365 Shipped
Brian Crower Valve Set - In & Ex
$499 Shipped
BC Valvetrain Combo
Stage 2 Camshafts/ Valve Spring/ Retainer Kit/ Brian Crower Valve Set
$1725 Shipped
Brian Crower 4.1L Stroker Kit
BC 4340 billet steel crank (86.4mm stroke). Avail. balanced or self-balanced.
BC 4340 Pro Series steel billet connecting rods w/ARP 220,000 psi fasteners.
CP aluminum forged pistons (any bore size, any compression ratio).
9310 nickel carbon steel alloy wrist pins available as a standard feature.
Ductile iron plasma top rings, tapered second ring, low tension oil rings.
86.4mm stroke req. block clearancing & removing piston squirters. Plugs incl.
Kits are available fully balanced ready to install or unbalanced.
ACL Race Bearings sold seperately.
$4199 Shipped
HKS Hi-Power Ti Exhaust
Inspired and designed from endurance and GT racing in Japan, HKS developed its Hi-Power Exhaust system for both turbocharged and naturally aspirated applications. HKS has incorporated this new race inspired offset muffler and piping design into many street applications, which offers a greater flow and higher-PRM power gains due to the less restrictive design. This is achieved by eliminating unnecessary bends for the straightest exhaust path. For turbocharged applications, the large and smooth exhaust flow allows greater exhaust velocity for better mid-range boost response and high-RPM power. Naturally aspirated vehicles also benefit from greater exhaust flow capacity as engine tuning levels increase. Certain applications are available in a Silent Hi-Power version which has an inner silencer built into the muffler. Like Drager Exhaust systems, Hi-Power Exhaust systems are made from SUS304 stainless steel muffler and tip assemblies. Depending on the application, Hi-Power muffler tips are 96mm, 115mm and 120mm in diameter, piping diameter ranges from 55mm to 95mm. Special Edition HKS Carbon Titanium Hi-Power Exhaust systems are exclusively available for certain popular applications. These exclusive versions of the Hi-Power Exhaust consist of a carbon fiber wrapped muffler shell, titanium tip, and polished SUS304 stainless steel piping. 6-10whp gain
$1375 Shipped
Add Helix Test Pipes For $99
GReddy SP2
The new SP2 features a 304 stainless steel muffler canister with extra strong 430 SS end caps that feature a deep, high polish. Large, high volume mufflers provide maximum flow with a deep, pleasing tone and are especially effective when used on vehicles with aftermarket turbocharger systems. The unique outer curled oval tip (115 x 110mm dia.) is embossed with the famous GReddy logo. Employing state-of-the-art robotic seam welding, the single wall canisters feature increased rigidity for maximum durability and life. With over 35 types of internal perforated tubes, each SP2 application is specifically tuned for the best combination of sound and performance. The new SP2 also features thick walled (1.5mm), polished 304 stainless steel mandrel bent piping for better resonance and vibration control and enhanced corrosion resistance and durability. New lightweight, flared and stamped stainless steel flanges are also used to provide improved sealing characteristics. 6-10whp gain.
$475 Shipped
Tanabe Touring Medallion
A refined level of performance and driveability is available in the MEDALION TOURING.
The elegant, well defined appearance of MEDALION TOURING is mature, and matches the artistry of a tastefully built, highly tuned machine.
$775 Shipped
Helix V2 SS Test Pipes
The Helix Test Pipes are excellent for the performance minded 350z or G35 owner. These testpipes feature 2.25" SS304 fully polished stainless steel construction and includes o2 sensor bungs.
Furthermore these new V2 test pipes feature a reinforced support bracket that eliminates exhaust, y-pipe, and header flex under acceleration / deceleration. Without these support brackets Y-pipes, headers, and exhausts are prone to cracking.
03-05 VQ35 $135 Shipped
Berk High Flow Cats
The Berk High Flow Cat Pipes are 49 state legal, and will still pass strict California SMOG emissions tests. These high flow cats use new metallic spun high converters for smooth uninterrupted exhaust flow and lighter weight. Adds 5-8HP on an otherwise 100% stock 350Z.
• Spun high flow catalytic converters.
• Secondary Wide band O2 Sensor ports included for left bank and right bank cylinders. Wideband plugs included if ports are not in use.
• 100% bolt on. NO cutting, splicing, hacking, etc.
• SUS304 Stainless Steel Tubing & Flanges, unlike most other brands that use mild steel flanges.
• True 60mm piping (2.36") tubing unlike most other brands that use 57.15mm (2.25”) piping.
03-05 VQ35 $425 Shipped
06-07 VQ35HR $475 Shipped
Looking for a super rare JDM engine component?
PM for Price
Old Feb 25, 2008 | 10:18 PM
Drtybrd61's Avatar
do you have a sale price for the Fujitsubo for a coupe?
Old Feb 26, 2008 | 03:45 PM
gruppe-s's Avatar
Former Sponsor
What exhaust are you interested in?
Fujitsubo is Special order from Japan 10-14 weeks.
Thanks
Old Feb 26, 2008 | 03:48 PM
ShanesG's Avatar
OH SHIIIT....ITB's on a vq, thats siiiiick
Old Feb 26, 2008 | 10:34 PM
Drtybrd61's Avatar
Thanks
I'm looking for the Fujitsubo Legalis R for the G35 coupe. Let me know how much for the Y-Pipe as well, please. Thanks!
Old Feb 27, 2008 | 01:44 PM
lniivedl's Avatar
Is the INJEN intake the new MR version?
Also do you have any in the BLACK finish?
Lastly any news on the CARB approval for the injen?
Old Feb 27, 2008 | 03:28 PM
gruppe-s's Avatar
Former Sponsor
Yes the MR is the only intake available for the G35
Black one is special order only chrome in stock.
Injen is still in the works with CARB. According to them the process is a pretty long one for CARb approval. If CARB is a concern I suggest AEM
Thanks
Old Feb 27, 2008 | 03:29 PM
gruppe-s's Avatar
Former Sponsor
Legalis R is $899 Shipped
Y pipe is $499 Shipped
Thanks
Old Feb 28, 2008 | 04:29 PM
gruppe-s's Avatar
Former Sponsor
Old Feb 28, 2008 | 04:56 PM
lexusk8's Avatar
So is the Skunk2 spacer only good for the '03-'05 350Z, not the G?
Old Feb 28, 2008 | 06:14 PM
gruppe-s's Avatar
Former Sponsor
According to Skunk 2 the plennum spacer fits 03-05 350Z and G35 VQ35 engine not the HR model.
Thanks
Old Feb 28, 2008 | 09:06 PM
Nikos35's Avatar
is ththe Injen w/TI tips the track model? I may be ordering in the morning....
Old Feb 29, 2008 | 11:03 AM
Nikos35's Avatar
10:00 A.M. ? come on mannnnnnn!!!!
Old Feb 29, 2008 | 01:57 PM
Nikos35's Avatar
I see you changed your prices on Injen, I will order elsewhere.....
Old Feb 29, 2008 | 03:19 PM
gruppe-s's Avatar
Former Sponsor
