Engine-Vendor Includes cams, clutches, flywheels and all other power related components.
AAM Comptition July 4th Sale!!
Old Jul 3, 2008 | 12:54 PM
davew@altered's Avatar
Arrow AAM Comptition July 4th Sale!!
AAM Competition Angled Plenum Spacer
The AAM Angled Plenum Spacer for the G35, 350Z & FX35 is the ultimate upgrade in the quest for more power. THIS IS OUR MOST POPULAR UPGRADE FOR THE VQ35DE - AND THE BIGGEST HORESPOWER GAIN FOR THE MONEY! The billet aluminum spacer sits between the factory upper and lower plenum, creating a larger volume to rush towards the cylinders. Power gains across the board. The upper RPM range opens up considerably. You get to keep your factory engine cover, your factory strut bar (350Z) and gain 10-15HP in under an hour. 2006 350Z/G35 gain between 6-10hp on average.
Features of the AAM Spec Angled Plenum Spacer
* Proprietary ANGLED Design Provides Additional Air Flow to the Front Cylinders
* Retains Factory Strut Bar (350Z) and Engine Cover
* Stock-like Appearance
* Custom Cut In House on Our CNC Mill
* Easy Install and Removal
* Built with Strong and Lightweight 6061-T6 Aluminum
Package Contents
* AAM Spec Angled Plenum Spacer
* All Bolts Required for Securing the Plenum
* Modified OEM Gasket to Reseal the Top Plenum
* Spacers for the Strut Tower Brace
* Detailed Directions
AAM Comp Stage 1 Fuel System
BENEFITS:
• Adjustable base fuel pressure (35psi to 65psi)
• Fuel pressure increases with boost pressure
• Fuel rails are individually fed for equalized fuel flow
• Billet Machined fuel rails for long, leak proof life
• Larger inside fuel rail diameter increases fuel flow
• Redesigned injector hood that streamlines fuel flow (internal portion of the fuel rail that delivers the fuel to the top of the injector)
• Allows fuel to flow to the injectors more easily
• Delivers more fuel for more power
Our bolt-in kit is a direct replacement and upgrade to the stock, factory fuel system. Included is a High Performance set of AAM Spec CNC Billet Aluminum Fuel Rails with a 500% flow improvement over stock, a complete set of –AN stainless steel lines and fittings, fully pre-assembled and pressure tested to greatly reduce installation time, a boost referenced fuel pressure regulator, and precision fuel pressure gauge. Together with a full set of instructions complete with detailed photos for an easy, straightforward installation. This kit is a must for any high-horsepower Nissan 350Z or Infinity G35!
We currently have AAM Competition Angled Plenum Spacers and AAM Comp Stage 1 Fuel Systems in stock! PM for best pricing!!!
Sale ends 7/14/08
Old Jul 7, 2008 | 09:25 AM
All PM's replied!
Old Jul 8, 2008 | 09:07 AM
Bump!
Old Jul 10, 2008 | 09:01 AM
PM's replied. The spacers are going fast!
Old Jul 10, 2008 | 02:04 PM
We now have AAM Throttle Body Spacers in Stock! PM for Special Pricing!
The AAM Spec. Throttle Body Spacer is a great addition to any upgraded 350Z or G35. Each AAM Spec. Throttle Body Spacer comes pre-tapped with three vacuum ports. This saves both time and money when running vacuum lines (no need to tap the factory intake plenum with this spacer). Because you have more vacuum ports available you can run components seperately (ie. map sensor, boost gauge, fuel pressure regulator, boost controller, etc.) which improves both their performance and reliability. This will fit any VQ35DE engine
Old Jul 14, 2008 | 09:22 AM
All PM's replied
Old Jul 16, 2008 | 09:12 AM
All PM's replied. PM me for best pricing on all AAM Competition Products!
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
joel extreme
SOCAL Meetings & Events
Jul 23, 2015 04:13 AM
