ATS/Carbonetic Clutches- Race tested by the #1 Carbonetic Distributor!!!
SubscribeATS/Carbonetic Triple Disc Clutch:
Carbonetics/ATS presents its carbon clutch produced by a joint development with ACROSS Corporation. ACROSS Corporation is a leading carbon manufacture with the most advanced CC composite technology in the world. The super light and heat resistant characteristics of CC composite gives a driver truly exceptional strength, response, and durability. Its operation is very smooth and easy on the transmission. From the street to the racetrack, under any driving condition, ATS carbon clutch enhances your driving performance and excitement.
Super shift response- The weight of ATS carbon friction disk is only 400g. It is exceptionally light.
Super heat-resistance- Designed to resist over 2,000 degrees Centigrade (3,650 degrees Fahrenheit)
Super deformation-resistance- The deformation is 1/10 of iron. You always get a smooth & crisp engagement
Super easy operation- Operating ATS clutch is very easy, even when driving up a slope and in a traffic congestion Super power transfer- 10% to 30% higher transfer capacity than the metal clutch
Super durability- Due to the various favorable characteristics of carbon, the clutch has a very long life
-ATS carbon clutch comes with ATS light flywheel made of carbon steel. Includes pull to push conversion.
We are the #1 Carbonetic Clutch dealer in the country! Buy with confidence!
These are the same clutches we race with in our time attack cars!
Call or PM Me for Best Pricing!
770-792-0202
770-792-0202
They chatter a little bit when the clutch pedal is down, but its not bad. While in gear and between shifts its quiet and engages very smoothly.
we still have a couple of these left guys.
