Engine-Vendor Includes cams, clutches, flywheels and all other power related components.
Act & Fidanza Clutch And Flywheel Thread -xmas Sale
Old Dec 4, 2008 | 06:08 PM
Iperformancellc's Avatar
ACT BLOW OUT SALE
SPEC & CLUTCH MASTERS 10-20% OFF
(Updated Dec 1st 2008)
ACT CLUTCH MODEL & PART #S
ALL Items below are In Stock
*Other models ship direct *
MUST PM FOR PRICING!
CLUTCH INFORMATION
HD: Heavy Duty Pressure Plate
The ACT Heavy Duty Pressure Plate is an excellent combination of increased torque holding and pedal feel for most daily driven cars. The HD pressure plate provides 30% increase in clamp loading while creating only a moderate increase in pedal feel thanks to ACT's special, single diaphragm design.
Part #: NZ1-HDSS
Vendor: ACT
Description: ACT 03-06 Nissan 350Z / 03-06 Infiniti G35 Coupe/Sedan Heavy Duty Performance Street Clutch Kit
G6: 6-Puck Sprung Race Disc
The ACT 6-Puck Sprung Hub Race Disc is SFI certified, so it is legal for all forms of racing that require SFI compliance. An ACT G6 race disc has a very durable friction surface with good spline life. The G6 was designed for a highly modified car that is drive to, on and from the track, as long as harsher engagement is acceptable. The sprung hub helps to reduce driveline shock and be relatively quiet compared to an unsprung hub, though the G6 can still be noisier than a full face disc and will have some chatter.
Part #: NZ1-HDG6
Vendor: ACT
Description: ACT 03-06 Nissan 350Z / 03-06 Infiniti G35 Sedan/Coupe Heavy Duty Sprung 6 Puck Clutch Kit
PM FOR PRICE (Make sure to include Zip Code)
R6: 6-Puck Solid Race Disc
The reduced inertia of the ACT 6-Puck Solid hub allows for very fast shifts at the expense driveability. An ACT R6 race disc friction surface has very good durability but will have shortened spline life. ACT designed the R6 for a highly modified track cars where harsher engagement is expected and some clutch chatter is not a problem. The 6-puck layout of the R6 will absorb, and dissipate, more heat than a 4-puck unit. The ACT 6-Puck Solid Hub Race Disc is legal for all forms of racing that require SFI compliance. JSC does not recommend the R6 for any road going car.
Part #: NZ1-HDR6
Vendor: ACT
Description: ACT 03-06 Nissan 350Z / 03-06 Infiniti G35 Coupe/Sedan Heavy Duty Solid 6 Puck Clutch Kit
Special Order no cancellations
PROLITE
  • Recommended for Track and Road Race Use
  • Maximum gear life – Gear will not Wear Out or Fall Off
  • Serviceable – Can be Resurfaced with no Need to Purchase Additional Parts
  • Chrome-Moly Forgings are Three Times More Rigid than Aluminum
  • Quick Throttle Response and Acceleration
  • Lightest and Lowest Inertia
  • Reduced Drivability
    *13.2 LBS
    Prolite
    MODEL # 600220
    Fits:
    2003 - 2006 350Z (ALL SUB MODELS) - 2003 - 2006 G35 (Base, X)
    STREET LITE
    ACT Streetlite Steel Flywheel: The ACT Streetlite flywheel is made from premium quality forged Chrome-Moly steel, CNC machined, and balanced. It also features an induction-hardened integral ring gear, and is durable and thick enough to be resurfaced. Certified to SFI Specification 1.1.
    Material: Chromoly Steel
    Weight: 16.9 lbs
    Street Disc
    Part #: 3000409
    Vendor: ACT
    Description: ACT 03-06 Nissan 350Z / 03-06 Infiniti G35 Coupe/Sedan Performance Street Disc
    Part #: 600215
    Vendor: ACT
    Description: ACT 03-06 Nissan 350Z /03-06 Infiniti G35 Coupe/Sedan StreetLite Flywheel (16.9 lb)
    FIDANZA CLUCH MODEL & AND PART #'s
    Fidanza Clutch Kits will help you put power to the wheels with different clutch package stages based on the modifications you have added to your car. This includes everything from stock, to full out race cars. These kits include the pressure plate, applicable bearings(s), disc, and alignment tool. If you need your clutch rapidly, call or email us and we can usually arrange expedited shipping for an additional cost. Stage 5.4 kits are available, but are not recomended, even for track cars.
    Stage 4.3: Great Street/Strip clutch. High-clamp pressure plate, ceramic disc, bearings and a tool.
    Part #: 341443
    Vendor: Fidanza
    Description: Fidanza 03-06 350z/03-06 G35 4.3 Clutch Kit
    Stage 3.2: High clamp pressure plate, Kevlar disk, bearings and tool.
    Part #: 341442
    Full Race Clutch. High-clamp pressure plate, Sintered Iron Solid Hub Disc, bearings and a tool.
    NOT Recommended for Street Use.
    Part #: 341444
    FLYWHEELS
    Fidanza Aluminum Flywheel: Fidanza flywheels are made from 6061 T6 billet aluminum for strength and weight reduction. Fidanza flywheels are CNC machined at a constant speed for precise fit and finish, feature a replaceable 1045 high-carbon steel friction plate with AN military-grade fasteners and a hardened 1050 ring gear. These features make this a great lightweight flywheel at a great price.
    FITMENT: 2003-2006 Nissan 350Z & G35 (VQ35DE only)
    Description Part #:
    Fidanza
    Aluminum Flywheel 143351
    JBK PERFORMANCE
    F# 866.295.3077
    P# 407.412.9551
    http://www.JbkPerformance.com
Old Dec 6, 2008 | 06:21 PM
Bump It Up
Old Dec 11, 2008 | 04:42 PM
More Act In Stock
Old Dec 14, 2008 | 04:56 PM
Clutch Sale Galor
Old Dec 18, 2008 | 04:19 PM
Bring It Up !
Old Dec 26, 2008 | 04:57 PM
Spec and Competition Clutch now available.
jsimonk
Dec 22, 2023 03:49 PM
EPG35
Aug 16, 2015 04:52 PM
TurboEE
Jul 31, 2015 10:41 AM
neight
Drivetrain
Jul 28, 2015 04:47 PM
Buggzb86
Drivetrain
Jul 25, 2015 11:22 PM
