Engine-Vendor Includes cams, clutches, flywheels and all other power related components.
350Z\G35\G37 Xmas Clutch Sale, ACT-CLUTCHMASTERS-FIDANZA
Old Dec 10, 2008 | 06:42 PM
Iperformancellc's Avatar
Smile 350Z\G35\G37 Xmas Clutch Sale, ACT-CLUTCHMASTERS-FIDANZA
ACT BLOW OUT SALE
SPEC, CLUTCH MASTERS & FIDANZA
(Updated Dec 10th 2008)
ACT CLUTCH
CLUTCH INFORMATION
HD: Heavy Duty Pressure Plate
The ACT Heavy Duty Pressure Plate is an excellent combination of increased torque holding and pedal feel for most daily driven cars. The HD pressure plate provides 30% increase in clamp loading while creating only a moderate increase in pedal feel thanks to ACT's special, single diaphragm design.
Part #: NZ1-HDSS
Vendor: ACT
Description: ACT 03-06 Nissan 350Z / 03-06 Infiniti G35 Coupe/Sedan Heavy Duty Performance Street Clutch Kit
G6: 6-Puck Sprung Race Disc
The ACT 6-Puck Sprung Hub Race Disc is SFI certified, so it is legal for all forms of racing that require SFI compliance. An ACT G6 race disc has a very durable friction surface with good spline life. The G6 was designed for a highly modified car that is drive to, on and from the track, as long as harsher engagement is acceptable. The sprung hub helps to reduce driveline shock and be relatively quiet compared to an unsprung hub, though the G6 can still be noisier than a full face disc and will have some chatter.
Part #: NZ1-HDG6
Vendor: ACT
Description: ACT 03-06 Nissan 350Z / 03-06 Infiniti G35 Sedan/Coupe Heavy Duty Sprung 6 Puck Clutch Kit
PM FOR PRICE (Make sure to include Zip Code)
R6: 6-Puck Solid Race Disc
The reduced inertia of the ACT 6-Puck Solid hub allows for very fast shifts at the expense drive ability. An ACT R6 race disc friction surface has very good durability but will have shortened spline life. ACT designed the R6 for a highly modified track cars where harsher engagement is expected and some clutch chatter is not a problem. The 6-puck layout of the R6 will absorb, and dissipate, more heat than a 4-puck unit. The ACT 6-Puck Solid Hub Race Disc is legal for all forms of racing that require SFI compliance.
Part #: NZ1-HDR6
Vendor: ACT
Description: ACT 03-06 Nissan 350Z / 03-06 Infiniti G35 Coupe/Sedan Heavy Duty Solid 6 Puck Clutch Kit
Special Order no cancellations
PROLITE
  • Recommended for Track and Road Race Use
  • Maximum gear life – Gear will not Wear Out or Fall Off
  • Serviceable – Can be Resurfaced with no Need to Purchase Additional Parts
  • Chrome-Moly Forgings are Three Times More Rigid than Aluminum
  • Quick Throttle Response and Acceleration
  • Lightest and Lowest Inertia
  • Reduced Drivability
    *13.2 LBS
    Prolite
    MODEL # 600220
    Fits:
    2003 - 2006 350Z (ALL SUB MODELS) - 2003 - 2006 G35 (Base, X)
    STREET LITE
    ACT Streetlite Steel Flywheel: The ACT Streetlite flywheel is made from premium quality forged Chrome-Moly steel, CNC machined, and balanced. It also features an induction-hardened integral ring gear, and is durable and thick enough to be resurfaced. Certified to SFI Specification 1.1.
    Material: Chromoly Steel
    Weight: 16.9 lbs
    Street Disc
    Part #: 3000409
    Vendor: ACT
    Description: ACT 03-06 Nissan 350Z / 03-06 Infiniti G35 Coupe/Sedan Performance Street Disc
    Part #: 600215
    Vendor: ACT
    Description: ACT 03-06 Nissan 350Z /03-06 Infiniti G35 Coupe/Sedan StreetLite Flywheel (16.9 lb)
    FIDANZA CLUTCH MODEL & AND PART #'s
    Fidanza Clutch Kits will help you put power to the wheels with different clutch package stages based on the modifications you have added to your car. This includes everything from stock, to full out race cars. These kits include the pressure plate, applicable bearings(s), disc, and alignment tool. If you need your clutch rapidly, call or email us and we can usually arrange expedited shipping for an additional cost. Stage 5.4 kits are available, but are not recomended, even for track cars.
    (IN STOCK)
    Stage 4.3: Great Street/Strip clutch. High-clamp pressure plate, ceramic disc, bearings and a tool.
    Part #: 341443
    Vendor: Fidanza
    Fitment: Fidanza 03-06 350z/03-06 G35 4.3 Clutch Kit
    (SHIPS DIRECT)
    Stage 3.2: High clamp pressure plate, Kevlar disk, bearings and tool.
    Part #: 341442
    Vendor: Fidanza
    Fitment: Fidanza 03-06 350z/03-06 G35 Clutch Kit
    Part #:
    341443
    Vendor: Fidanza
    Stage 5.4: Full Race Clutch. High-clamp pressure plate, Sintered Iron Solid Hub Disc, bearings and a tool.
    Part #:
    341444
    Vendor: Fidanza
    FLYWHEELS
    Fidanza flywheels are made from 6061 T6 billet aluminum for strength and weight reduction. Fidanza flywheels are CNC machined at a constant speed for precise fit and finish, feature a replaceable 1045 high-carbon steel friction plate with AN military-grade fasteners and a hardened 1050 ring gear. These features make this a great lightweight flywheel at a great price.
    FITMENT: 2003-2006 Nissan 350Z & G35 (VQ35DE only)
    (IN STOCK)
    Description Part #: 143351
    Fidanza Aluminum Flywheel
    CLUTCH MASTERS
    Clutch Masters Kits Include:
    Pressure Plate
    Clutch Disc
    Throw-out Bearing
    Pilot Bearing or Bushing (when applicable)
    Alignment Tool
    FX100:Heavy duty pressure plate (40-65% increase over stock pressure) and steel-backed organic lined disc, smooth engagement. For cars w/ bolt-ons / 50-shot NOS. This assembly is designed to provide extended life and superior holding power for cars with moderate power upgrades and/or more enthusiastic driving in abusive conditions. The pressure plate offers 40-65% more clamping force than a stock cover. Most organic discs provided in Clutch Masters' assemblies include steel-backed lining to enhance the structural integrity of the material which is complemented by the highest quality hub assemblies available to ensure durability and driveability.
    FX200: Heavy duty pressure plate and full-face Kevlar lined disc for smooth engagement & long life. Recomended for cars w/ basic non-forced induction bolt-ons/50 hp shot of NOS. This clutch offers comparable torque capacity as Stage 1, but provides exceptionally smooth engagement & extended life. This is due to the full-face Kevlar disc. This clutch is designed for the daily driver that desires smooth & effortless transitions.
    Kevlar clutch kits require a break-in period of 500-750 miles under normal driving conditions.
    FX300: Heavy duty pressure plate and segmented Kevlar disc for exceptional holding power & long life. Firm, positive pedal feel. For bolt-ons / 80-shot NOS, small turbo upgrades for NA cars. The perfect clutch for aggressive drivers that still desire smooth engagement. Clutch Masters' Stage 3 clutches utilize a segmented Kevlar disc. This will provide more holding power than Stage 1 & 2, yet it still offers exceptionally smooth driveability and long life. Combined with our aluminum flywheel, this an excellent performance upgrade.
    FX400: Heavy duty pressure plate, 4-puck ceramic sprung disc for quick engagement and tremendous holding power. Harsh, agressive engagement. Turbo upgrades, higher boost, etc. The clutch for aggressive drivers. This is the perfect road-racing application. Stage 4 utilizes a 4-puck ceramic sprung disc complemented by a bulletproof hub assembly. It is designed for cars with significant power upgrades. Engagement is hard and quick.
    FITMENT: 2003-06 Nissan 350Z / 2003-06 Infiniti G35 (VQ35DE only)
    Description: Part #:
    FX100 (stage I) cm06-047-HD00
    FX200 (stage II) cm06-047-HDKV
    FX300 (stage III) cm06-047-HDTZ
    FX400 (stage IV) cm06-047-HDCB
Old Jul 30, 2009 | 02:54 PM
Sanclementeg35's Avatar
ACT Heavy Duty Street Clutch / ACT Streetlite Flywheel
Shipped to 92672
thanks
Old Aug 5, 2009 | 06:16 PM
ACT Heavy Duty Street Clutch / ACT Streetlite Flywheel shipped to 92672
Old Aug 5, 2009 | 10:22 PM
Aero09's Avatar
ACT Heavy Duty Street Clutch shipped to 32216
Old Nov 19, 2009 | 05:26 PM
cwhealon78's Avatar
Act g6 kit for 04 coupe shipped to 33596 thanks
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Engine - Intake/Fuel CDN
Jul 24, 2015 02:21 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
vstypicals
Jul 20, 2015 10:55 PM
