Engine-Vendor Includes cams, clutches, flywheels and all other power related components.
NRG Items Now Available at Statik..P/S Tank // Oil Catch Can // Epac // Ground Kit
Old Aug 1, 2009 | 05:22 AM
mrwong@statik's Avatar
Hey Guys,
Just wanted to bring fellow members a couple of new items.
Power Steering Tank - PM for Pricing!
Lightweight aluminum construction
Improves power steering performance and feedback
Reduces reservoir bubbles resulting in less oxidation from fluid and water build up
Provides consistent power steering fluid pressure
Reduces chances of leakage and pressure loss from high stress driving such as drifting, autocross, road and track racing.
Oil Catch Can - PM for Pricing!
Features:
Stainless Steel Construction
Indicator Hose
Vacuum pressure sender adapter
Mounting hardware and hoses included
Installed connecting the PCV Valve or pressure release hose to the intake pipe, this unit captures and stores excess oil coming from valve cover. This results in clean air recirculating back into the intake unlike the factory system which puts the release tube directly back into the engine. Results a decrease in valve cover pressure prolonging engine life and increasing performance.Also a must in any competition car due to regulations concerning oil on the track.
Epac -100 - PM for Pricing!
Connected to battery terminals, this unit stabilizes power output to all electrical components drawing power from battery. Using an independent power source, this unit boosts batterypower when under high loads, thus regulating fluctuations coming from the battery that can result in loss of power or responsiveness from ignition system components. Can also improve interior lighting as well as stereo equipment performance.
Ground Kit - PM for Pricing!
Features:
Copper center hub
High Quality 12 gauge low resistance wires with smoke titanium silicone wrap.
Installed on battery? negative terminal or onto chassis, this unit centralizes the grounding point of the electrical mechanisms of the vehicle. This causes less fluctuation for the electrical system and can improve overall performance and responsiveness of the engine end electrical components resulting from proper grounding. A must-have for any vehicle with engine swaps since grounding tends to be an issue with these types of performance modifications.
Billet Aluminum Oil Cap - $40 shipped.
Old Aug 1, 2009 | 08:18 AM
O HELLA OEM's Avatar
PM me price for the Powersteering tank and the oil catch can.
Old Aug 1, 2009 | 09:43 AM
myroncuz's Avatar
p/s tank and epac cheapest price shipped to 96701
Old Aug 1, 2009 | 04:12 PM
pms replied..
Old Aug 1, 2009 | 04:15 PM
are these hard to install?
do both the ps tank and oil catch can
use the oem mounting points?
Old Aug 1, 2009 | 04:27 PM
Nope easy to install comes with all fittings and brackets.
The PS tank will bolt where the OEM one bolts onto.
The catch can is personal preference. The bracket is universal so can be mounted pretty much anywhere you'd like. However it can not be mount horizontally
Old Aug 2, 2009 | 11:09 PM
added Billet oil cap.
Old Aug 4, 2009 | 04:20 AM
pms replied.
Old Aug 4, 2009 | 10:04 AM
drifts500's Avatar
PM for power steering tank~! thanks
Old Aug 8, 2009 | 03:31 AM
pms replied..
Old Aug 13, 2009 | 06:55 AM
pms replied.
Old Aug 19, 2009 | 05:47 AM
myroncuz's Avatar
guys, i just installed the epac today and what a difference... no, its not in my head, my car picks up way quicker then before... i first noticed it when i was in 2nd gear in low rpm where it usually drags and it picked up quicker. best 70 dollar investment i have made so far..
Old Aug 19, 2009 | 11:43 PM
jlinc04's Avatar
I just got the oil catch can today, has anyone installed this yet?, debating about where I want to put it
Old Aug 25, 2009 | 05:05 AM
pms replied..
Old Aug 30, 2009 | 08:41 AM
jlinc04's Avatar
Just installed the NRG Grounding Kit...
