Engine-Vendor Includes cams, clutches, flywheels and all other power related components.
Special Price on Greddy Turbos and Intercoolers! Check it out!!
Old Aug 18, 2009 | 01:51 PM
Mike@CZP's Avatar
We have this great deal going for 03-06 G35 owners looking for turbos and intercoolers. Check out the pricing and PM if you are interested. List price on these is over $10,000!
Greddy Turbos Kit for $6,500 Shipped!!
Greddy Turbos and Intercooler Kit for $7,500 Shipped!!
Shipped Price only includes shipments in the USA.
Greddy G35 03-06 Bolt-On Turbo Kit
Part#: 11520077
Description: Leading the way in bolt-on turbo kits for normally-aspirated engines, GReddy turbo kits provide instant horsepower gains with less time and money while still having the potential for upgrading for even more power. Designed with turbochargers at the beginning end of their efficiency range, gives the buyer the option to increase power levels substantially, before having to ever upgrade the kit’s turbo. Unlike most turbo kits on the market today, our turbo kits are specifically designed for optimal response and performance while maintaining drivability, comfort and reliability. Since they are based on completely stock engines, these kits come with all the necessary basics, manifold, turbocharger, downpipe adapter, piping, hardware and heat-shields, in most kits, they even include pre-tuned fuel enrichment. A few of the kits are covered under CARB E.O. numbers, which make them 50-state street legal. If competition use is your goal, there are many GReddy upgrades (intercoolers, blow-off valves, fuel management and boost controllers) to boost the power output even further.
Greddy G35 03-06 Intercooler Kit
Part#:12020153
Description: The addition of a GReddy intercooler is one of the best ways to safely increase horsepower in a turbocharged engine. By reducing the engine's inlet temperatures, a denser air charge will enter the engine; this can make more horsepower at the same boost level and even more power at higher boost levels. Even if there is a factory-installed intercooler, generally these stock units are not ideal even for factory boost levels. They are usually mounted in awkward locations and become very susceptible to heat saturation. They are not ideal for increased boost levels. Our vehicle specific kits include all the necessary mounts, aluminum piping, hoses, and clamps required to install the kit. All kits are designed with specific cores to provide an ideal concession of cooling and flow, with the added benefit of aggressive looks and style. This is achieved by finding an ideal position and configuration for a wide range of boost levels. Our engineers properly size the number of rows in the core and tune the internal core with either a free flowing V-spec. core, our new M-Spec. bar-and-plate core, or our R-Spec core with a different inner fin patterns . The V-spec and R-Spec cores are a lightweight air-to-air, tube and fin design with a highly efficient tube design, which allows smooth ambient flow for optimum heat dissipation and flow to engine cooling systems. Although only offered in very limited sizes, the M-Spec core is an economical compromise that has performance, which lies between the free flowing V-spec. and the extreme cooling potential of the R-Spec. cores. GReddy intercoolers kits offer a great balance of heat exchanging efficiency and flow. The ends of the cores are TIG-welded and capped off with our smooth flowing heavy-duty cast aluminum GReddy endtanks. Lightweight mandrel bent aluminum piping and/or cast aluminum elbows, complete with hose couplers, are used to route air charge smoothly to and from the intercooler.
Old Aug 19, 2009 | 12:54 PM
Mike@CZP's Avatar
bumped!!
Old Aug 21, 2009 | 12:51 AM
Mike@CZP's Avatar
bump
Old Aug 24, 2009 | 04:59 PM
Mike@CZP's Avatar
bumped!!
Old Aug 25, 2009 | 05:19 PM
Mike@CZP's Avatar
bumped!!
Old Aug 25, 2009 | 08:36 PM
GT-ER's Avatar
Damn, that's a nice price. How much for the kit without intercooling?
Old Aug 26, 2009 | 01:54 PM
Mike@CZP's Avatar
PM Sent
Old Aug 28, 2009 | 08:40 PM
Mike@CZP's Avatar
bumped!!
Old Sep 1, 2009 | 03:50 PM
Mike@CZP's Avatar
bumped!!
Old Sep 2, 2009 | 08:55 PM
Mike@CZP's Avatar
bumped!!
Old Sep 9, 2009 | 08:25 PM
Mike@CZP's Avatar
bumped!!
Old Sep 11, 2009 | 05:59 PM
Mike@CZP's Avatar
bumped!!
Old Sep 14, 2009 | 06:11 PM
Mike@CZP's Avatar
bumped!!
Old Sep 16, 2009 | 03:48 PM
Mike@CZP's Avatar
bumped!!
Old Sep 16, 2009 | 03:52 PM
Sylvan lake V35's Avatar
How much for just the intercooler shipped to
Canada, T4S-1S5
