Engine-Vendor Includes cams, clutches, flywheels and all other power related components.
Mishimoto Products (Radiators, Thermostats, Carbon Fiber Oil Catch Cans & More!)
Old Nov 11, 2009 | 08:25 AM
Marinelli Motorsports's Avatar
03-07 G35 Performance Aluminum Radiator
The Mishimoto performance aluminum radiator for the Infiniti G35 is the ideal upgrade to the stock G35 radiator. Designed and specifically engineered to maximize cooling efficiency by up to 30%, boost engine functions and protect your car from overheating. Whether you use your Infiniti for daily driving or take it to the track, many people overlook the importance of installing an upgraded radiator in their engine. A stock radiator can not handle the heat that comes along with having a great deal of horsepower. The Mishimoto Infiniti G35 radiator features a lightweight dual core, 100% brazed aluminum, and polished end tanks. Every Mishimoto Performance Radiator is a direct OEM fit, making installation effortless, no cutting or modification is required. All Mishimoto radiators come with a high pressure 1.3 bar Mishimoto radiator cap and an excellent warranty.
Specs:
Overall Size: 30" x 21" x 4.65"
Core Size: 16.53" x 29.05"
Rows: 2
Inlet: 1.4"
Outlet: 1.4"
Core Thickness: 2.2"
Tank Wall Thickness: .08"
Fill Neck: 1.25"
Drain Plug Thread Size: (M14) x 1.5"
Chassis Code: V35
Purchase Includes:
Mishimoto Radiator, Mishimoto Radiator Cap
Magnetic Drain Plug
Limited Lifetime Warranty
*NOTE - Works with both automatic and manual transmissions
New Products!
350Z/G35 Racing Thermostat, 2003-2008
The Mishimoto Nissan 350Z racing thermostat will promote greater cooling efficiency throughout your engine. A Mishimoto racing thermostat will significantly lower high engine temperature produced by modified and upgraded turbo applications. Once the engine is fully warmed up the Mishimoto racing thermostat will open up at a lower temperature than standard thermostats, also allowing the coolant to flow through the engine sooner thus reducing and maintaining cooler engine temperatures.
Specs:
Mishimoto Thermostat Activates at 62º C
OEM Thermostat Activates at 76.5º C
Mishimoto Carbon Fiber Oil Catch Can
Mishimoto has developed a carbon fiber oil catch can to make sure you’re getting the most out of your performance parts.
Over time harmful oil will build up inside the turbocharger, intake manifold, intercooler and piping. A Mishimoto Carbon Fiber Oil Catch Can will prevent this from happening while its sleek carbon fiber exterior will add a touch of style to your engine bay.
An oil catch can serves other important purposes as well. It will prevent oil from getting into pressured turbo plumbing, which can lead to couplers coming off under boost. Oil vapors can get into the intake system which will lower combustion temperatures and reduce overall efficiency. A Mishimoto Carbon Fiber Oil Catch Can will solve all these problems and give you the added security knowing that your performance parts are safe from harmful oil.
Contents:
4 O-Ring Clamps
Mounting Bracket and Hardware
Hoses and Hardware
Mishimoto Heavy Duty Transmission Cooler W/ Electric Fan
This transmission cooler comes with an eight-inch electric fan which is perfect for heavy duty trucks and supercharged or turbocharged applications to ensure transmission temperatures remain low and to keep your vehicle performing at its best.
Extend the life of your transmission with the Mishimoto Heavy Duty Transmission Cooler Kit. It is made with 100% aluminum and is tube and fin constructed. The kit includes an 8-inch electric fan and mounting equipment for universal installation.
Specs:
Aluminum Tube and Fin Construction
Overall Size
Height - 5.5"
Length - 12.5"
Thickness - 3.25"
Inlet - .34"
Outlet - .34"
Rows - 2
Kit Includes:
- Transmission Cooler
Nipple End Size: 3/8 Push-On
- 8" Electric Fan
CFM: 1100
RPM: 2800
Amps: 4
- Mounting Hardware
Please PM with Zip for best Pricing!
Old Nov 11, 2009 | 06:50 PM
All PMs replied!
Old Nov 11, 2009 | 07:18 PM
Mr. Samster's Avatar
How much for the radiator shipped to 92507
Old Nov 11, 2009 | 08:58 PM
You've got mail!
Old Nov 12, 2009 | 04:02 PM
All PMs replied!
Old Nov 13, 2009 | 10:54 AM
Bump!
Old Nov 14, 2009 | 09:25 AM
Bump!
Old Nov 16, 2009 | 04:20 PM
All PMs replied!
Old Nov 17, 2009 | 11:30 AM
Bump!
Old Nov 18, 2009 | 08:31 AM
All PMs replied
Old Nov 19, 2009 | 11:34 AM
All PMs replied!
Old Nov 20, 2009 | 09:49 AM
All PMS replied!
Old Nov 21, 2009 | 07:22 AM
All PMs replied!
Old Nov 23, 2009 | 06:24 AM
Bump!
Old Nov 24, 2009 | 09:47 AM
Bump!
