Engine-Vendor Includes cams, clutches, flywheels and all other power related components.
GroupBuy: SxExCx Custom HR Overflow Tank
Old Dec 17, 2009 | 10:43 AM
ttrank's Avatar
Grocery getter
Very nice!
Old Dec 17, 2009 | 11:07 AM
GreenGoblin's Avatar
The goblin resurrection
Great work again Sean.
Old Dec 17, 2009 | 12:52 PM
SxExCx's Avatar
Thanks guys for the kind words...please tell your HR friends about these!
Old Dec 26, 2009 | 08:35 PM
SxExCx's Avatar
who has some xmas money to spend? lol
Old Jan 1, 2010 | 03:55 PM
G35s-Q8's Avatar
Too bad it won't fit GCC spec, we have a different overflow tank, and it got radiator cap on it instead of the screw cap that comes in the U.S Spec.
It looks great, i wish if i can have one.
Old Jan 1, 2010 | 04:38 PM
Q8y_drifter's Avatar
Wouldn't it work if you buy this tank and an aftermarket radiator cap?
Old Jan 1, 2010 | 06:09 PM
SxExCx's Avatar
Please post a pic of your tank and radiator filler.
Old Jan 1, 2010 | 06:36 PM
Took this pic a long time ago...
I think we have a larger capacity tank. The radiator is also bigger I think.
Old Jan 1, 2010 | 07:47 PM
SxExCx's Avatar
It looks like it uses the same mounting points and I don't think the breather NEEDS the spring-loaded cap so my tank MIGHT work for you.
Old Jan 2, 2010 | 03:59 AM
G35s-Q8's Avatar
Our radiator is 26mm, the U.S spec is 16mm, at least that was for the older sedan's and 350z, if you look at the hose's, you'll notice that our's go from the top of the tank, but U.S spec goes from beneth, it should fit with some modification.
Old Jan 2, 2010 | 04:11 AM
Where does the 2nd hose (going downwards) go?
Old Jan 2, 2010 | 09:55 AM
Defratos's Avatar
You're Despicable
Ok wow I was slightly worried that that I missed this group bye, but since it won't fit GCC spec G's then I guess I shouldn't worry :P
Old Jan 2, 2010 | 10:58 AM
SxExCx's Avatar
the lower hose is just the overflow drain which will probably never have anything cover out of it. You could probably cut and reuse either hose to fit my lower fitting.
Old Jan 7, 2010 | 05:24 PM
SxExCx's Avatar
bump
Old Apr 24, 2010 | 01:49 PM
  #30
SxExCx's Avatar
bump
