Engine-Vendor Includes cams, clutches, flywheels and all other power related components.
Z1 350Z/ G35 Clutch and Flywheel Combo
Old Oct 7, 2011 | 12:18 PM
Z1Motorsports's Avatar
Z1 350Z / G35 Clutch and Flywheel combo
This package fits '03 - '06 350Zs and G35s and is capable of holding the power of all naturally aspirated and, depending on the options you choose, most forced induction applications up to 500 ft-lb tq. At the same time reducing the total weight of the clutch and flywheel assembly to 29.75 lbs vs 46.6 lbs stock.
Package includes :
Z1 Mild Performance Clutch Kit or Z1 Performance Street Clutch Kit (select below)
Z1 Ultra Lightweight flywheel
Braided SS hydraulic clutch line
Z1 Mild Performance Clutch info:
Clutch Type:
Z1 Motorsports Mild Performance Clutch - This kit utilizes a pressure plate built to OEM Spec clamping forces. This pressure plate along with any of the discs available in this kit allows the handling of more power without a change in pedal feel.
Z1 Motorsports Performance Street Clutch - This kit utilizes a high clamping force pressure plate with a low spring load. High clamping force refers to the increased amount of pressure that is applied to the clutch disc. A low spring load eases lateral force on the main thrust bearings in your engine, which is especially important during "dry" start-up, lessening the likelihood of "crank walk". This pressure plate along with any of the discs available in this kit will handle substantially more power with a slightly "heavier" pedal feel.
Friction Disc:
Standard Full Face - This is an OEM Type disc with a spruung hub and upgraded full friction surface to aid in driveability and engagement but also hold all of your NA Upgrades.
Sprung Hub 6 Puck - This is a sprung hub disc made up of ceramic "pucks" that provide a more aggressive engagement and hold a lot more power than the organic full face material. Couple this disc with the Performance Street Clutch to hold more than 500 ft lbs of torque.
Unsprung Full Face - This is a lightweight solid hub disc with an upgraded full friction surface to allow a more direct engagement without the aggressiveness of ceramic pucks.
Flywheel Type:
Z1 Light Weight - This Solid 4140 Forged Steel flywheel weighs 14.2 lbs. The light weight increases throttle response and helps reduce turbo lag for those boosted.
Z1 Mid Weight - This Solid 4140 Forged Steel flywheel weighs 21 lbs. The mid weight helps maintain engine RPM between shifts.
Exedy Lightweight - This Solid 4140 Forged Steel flywheel weighs 19.05 lbs. This flywheel is lighter than stock but still heavy enough to help reduce excess transmission noise (chatter).
PM for forum pricing
Old Oct 14, 2011 | 09:22 AM
Bump for a great Clutch/Flywheel combo. IN STOCK
Old Oct 17, 2011 | 02:40 PM
Ready to Ship!
Old Oct 20, 2011 | 02:55 PM
Bump!
Old Oct 22, 2011 | 05:47 PM
BUMP!
Old Oct 25, 2011 | 01:44 PM
BUMP!
Old Oct 27, 2011 | 11:32 AM
Bump!
Old Oct 29, 2011 | 11:11 AM
BUMP!
Old Nov 1, 2011 | 01:13 PM
Bump!
Old Nov 4, 2011 | 11:53 AM
Bump!
Old Nov 9, 2011 | 08:39 AM
Bump!
Old Nov 11, 2011 | 02:48 PM
Bump!
Old Nov 16, 2011 | 10:57 AM
Bump!
Old Nov 20, 2011 | 06:29 AM
Bump!
Old Nov 22, 2011 | 10:54 AM
Bump!
