Engine-Vendor Includes cams, clutches, flywheels and all other power related components.
ZSP Stage 2 Clutch and Flywheel Combo DEALS! Best kit under $500!
Old Nov 10, 2015 | 11:16 AM
ZSpeedPerformance's Avatar
ZSP Street Sport Clutch Kit + Nodular Iron Flywheel! $499.00! Clutch Kit Only $299.00
This is a great kit for all your bolt on Upgrades or as a stock replacement clutch kit.
ZSpeed Stage 2 Clutch and Flywheel Upgrade!
26LB Nodular Iron Flywheel helps reduce trans rattle, Common when going to a light weight one piece flywheel.
Flywheel saves about 4-5lbs off the stock unit and can be resurfaced if needed later on.
25% increase in holding power over the stock clutch.
Great street manners and higher quality than the stock clutch with upgraded clamping force
Kit comes with
Nodular Iron Replacement Flywheel
Stage 2 Pressure Plate
Performance Clutch Disk
Pilot Bearing
Alignment tool
Release Bearing
Fits
2003-2006 Nissan 350Z
2003-2007 Infiniti G35 Coupe
2003-2006 Infiniti G35 Sedan
Rdcstech
Nov 13, 2015 01:16 PM
RobbG35
Nov 10, 2015 02:03 AM
joel extreme
SOCAL Meetings & Events
Nov 9, 2015 05:24 PM
Elpuas3000
Engine - Intake/Fuel
Nov 6, 2015 11:54 AM
Datsunguy
Nov 5, 2015 11:28 PM
