Exhaust-Vendor Includes Headers, Test Pipes, Y-Pipes, High Flow cats and Cat-back Systems
Berk Technology Test Pipes and High Flow Cats! $1 Shipping
Old Aug 26, 2010 | 12:45 PM
Mike@CZP's Avatar
Hey guys, we are selling these Berk Technology Test Pipes and High Flow Cats with only $1.00 Shipping!! Click on "Add to Cart" to be directly linked to our secure website to place your order! PM with any other questions.
_____________________________
Berk Technology G35 Test Pipes, 02-05 Sedan, 03-06 Coupe, $162.99 Shipped!!
Description: Metallic substrate spun catalytic converters, OBDII & 49 state compliant. Full stainless steel construction. Metallic substrate offers higher flow and lighter weight. Uses advanced spiral wound ultra thin foil. Includes our custom made soft crush graphite collector gaskets for a leak free seal. These are made specifically for the new HR motor by BERK. Made with pride in the USA. As of January 1st, 2009, performance high flow cats are intended for off-road use only in the state of California.
Berk Technology Test Pipes, 07 + G35 Sedan, 08+ G37 Coupe: $225.99 Shipped!!
Description: Full stainless steel construction. Berk Technology Test Pipes offers higher flow and lighter weight. Uses advanced spiral wound ultra thin foil. Includes our custom made soft crush graphite collector gaskets for a leak free seal. These are made specifically for the new HR motor by BERK. Made with pride in the USA. As of January 1st, 2009, performance high flow cats are intended for off-road use only in the state of California.
Berk Technology G35 Metallic Substrate High Flow Cat 03-06 Sedan, 03-07 Coupe, $450.99 Shipped!!
Description: Metallic substrate HFC's. Spun catalytic converters, OBDII & 49 state compliant. Full stainless steel construction. Metallic substrate offers higher flow and lighter weight. Uses advanced spiral wound ultra thin foil. Perfect for forced induction use. Click on the "Large View" for a side by side comparison of the metallic substrate vs. standard ceramic substrate. Made in the USA.
Berk Technology G35 Metallic Substrate High Flow Cat 07-08 Sedan, $495.99 Shipped!!
Berk Technology G35 Aluminum Z-Tube, $114.00 Shipped!!
Berk Technology Y-Pipe / Cat Gaskets - G35, $23.99 Shipped!!
Description: **SOLD IN PAIRS** High temp compressed graphite with stainless steel fire crush ring. Thick material is also able to seal flanges that are slightly warped. Made in the USA.
Berk Technology Y-Pipe Gasket Replacement - G35, $14.99 Shipped!!
Description: Compressed aluminum & graphite media high temp gasket. 2 bolt gasket. Will work with 3.00" & 2.75" Y-Pipes. Will also work with OEM Y-pipe.
Berk Technology Motor Collector Gaskets - G35 HR, $30.98 Shipped!!
Description: Stop using RTV silicone to seal your flanges! Berk Technology is currently the only manufacturer in the world that makes these custom collector gaskets for the 07+ 350Z/370Z/G35/G37. Instead of using a bandaid approach to gasket sealing like our competition, Berk Technology make their own custom gaskets for this application. High temperature softcrush graphite gaskets seal even slightly warped flanges. These are sold in PAIRS.
You do NOT need to purchase these separately when using BERK HFC's or test pipes. They are already included!
NOTE: Our gaskets align perfectly with the OEM flange & our BERK flanges. Our R&D Dept has found that some manufactuerers do NOT machine their flanges correctly and will partially block the exhaust path.
Old Aug 27, 2010 | 12:57 PM
Mike@CZP's Avatar
bumped!!
Old Aug 31, 2010 | 12:39 PM
Mike@CZP's Avatar
bumped!!
Old Sep 1, 2010 | 04:09 PM
Mike@CZP's Avatar
All PM's Answered
Old Sep 2, 2010 | 06:23 PM
Mike@CZP's Avatar
bumped!!
Old Sep 3, 2010 | 03:40 PM
Mike@CZP's Avatar
bumped!!
Old Sep 6, 2010 | 04:02 PM
Mike@CZP's Avatar
bumped!!
Old Sep 8, 2010 | 04:52 PM
Mike@CZP's Avatar
bumped!!
Old Sep 10, 2010 | 01:26 PM
Mike@CZP's Avatar
All PM's Answered
Old Sep 13, 2010 | 04:01 PM
Mike@CZP's Avatar
Bumped!!
Old Sep 14, 2010 | 03:50 PM
Mike@CZP's Avatar
PM's Answered
Old Sep 15, 2010 | 03:43 PM
Mike@CZP's Avatar
bumped!!
Old Sep 17, 2010 | 03:13 PM
Mike@CZP's Avatar
bumped!!
Old Sep 20, 2010 | 04:42 PM
Mike@CZP's Avatar
bumped!!
Old Sep 21, 2010 | 04:56 PM
Mike@CZP's Avatar
PM's Answered
