Exterior-Vendor Includes spoilers, body kits, tail lights, gauges, shift knobs, and other styling components
G35 COUPE, G37 & 07 SEDAN Key Hole Cover (ESCUTCHEON)!
Old Sep 9, 2008 | 05:45 PM
  #61
1SickVeilsideZ's Avatar
Originally Posted by WhosUrBuddiee
Can you guys paint? Or send them just primered? My car is lambo orange.
PM sent!
Old Sep 10, 2008 | 06:59 PM
  #62
asdfman's Avatar
Price for ivory pearl to 08820 please
Old Sep 15, 2008 | 02:27 AM
  #63
HEGONE's Avatar
^+1 to 60056
Old Sep 19, 2008 | 04:28 PM
  #64
Bump!
Old Sep 20, 2008 | 05:00 AM
  #65
Dranom's Avatar
is this easy to pop off???
Old Sep 22, 2008 | 01:16 PM
  #66
^^Different ways to do it, but all should work just fine.
Thanks to our fellow G members for the quick write ups on the DIY and for doing the research.
Originally Posted by terrycs
*I take ZERO responsibility if you **** up your car following these directions*
Lock your door.
Pull the door handle as if you were going to open it, then put a rolled up towel in-between the handle and the door to keep it open.
Then using the pic below as reference, use a small flathead screwdriver or what ever you have that is able to get into the space to lift the tab up. As you are lifting the tab, pull on the cover to remove it.
When you receive the part it comes attached to the mounting plate. See pic below. You are going to have to follow the same procedure to remove it from the mounting plate as you will when you take it off the car. This will give you an understanding of what you need to do on the car to remove it.
Originally Posted by kmuniz78
SWEET! Thanks!
Instructions for removing driver's side keyhole cover; Give a real clean look:
1st - Locate the black cap on the inside of the driver's door (see pic)
Attachment 92497
2nd - Pop off cap; locate hex screw; difficult I know:
Attachment 92498
3rd - Use 5/32" hex rench to unscrew bolt (won't fall into door; has a saftey lip)
Attachment 92499
4th - Pop off keyhole cover (forgot to take pic); replace with new cover (also forgot to take pic)! Should look like this when done:
Attachment 92500
Old Oct 1, 2008 | 01:14 PM
  #67
Bump!
Old Oct 3, 2008 | 09:50 PM
  #68
crashnburn's Avatar
got one for an 03 coupe in WV2 - Diamond Graphite
Old Oct 5, 2008 | 01:35 PM
  #69
decarlod's Avatar
I followed the directions posted and I am having a little trouble. I dont see the hex screw. Is the cover just suppose to come off only on the car? I am little confused. My original key cover got came off already and the key hole is exposed. I pulled the handle all the way out and I still dont see the hex like in the pic.
Old Oct 5, 2008 | 01:39 PM
  #70
elayman's Avatar
i think you just cover it up? i dont think you need to remove anything else
Old Oct 5, 2008 | 05:11 PM
  #71
decarlod's Avatar
Its not going on. It looks like the clip might be wrong. I hope they didnt send the wrong one.
Old Oct 9, 2008 | 03:04 PM
  #72
crashnburn's Avatar
mine just fell off to last time i washed my car.... so i was wondering how it would stay on if i got one of these.... my piece doesnt look broken no but wont stay on good enough for me to trust leaving it hanging...3m sticky maybe?
Old Oct 18, 2008 | 09:00 PM
  #73
Dranom's Avatar
did you screw the bolts inside?
i installed mine few minutes ago. Very easy only took a few minutes
unscrew the bolt inside the door like the picture above. Gently pull the old cover out then snap the new one. put it back in and then screw the bolt
some pics of my install
finished product
Old Oct 20, 2008 | 09:17 AM
  #74
yakkolio's Avatar
^^ looks good!
Old Oct 26, 2008 | 02:30 PM
  #75
red98gst's Avatar
pm sent.
