FAQ & DIY Frequently Asked Questions & Do It Yourself- Sedan and Coupe. Updates Approved by Administrators and Moderators.
Air filter removal
Old May 16, 2003 | 06:48 PM
Growler's Avatar
Re: Air filter removal
I just did my K&N last week on my coupe (sedan the same). No need to pop rivets and disassemble. Here's my method with a few brused knuckles.
1) Remove One bolt holding to the inside of the frame.
2) Unsnap 4 clamps on box. (this is brused knuckles)
3) Unscrew the clamp on the convoluted rubber connector to throttle body assembly. Clamp closest to box.
4) Work the rubber tube back off the plastic tube attached to the box. This lets you move the rear section of the box around.
5) Lift up the rear section of the box and push back. Box will open enough for you to see the filter...pull it back, up and out.
6) Insert the K&N, it's tight, but doeable.
7) When K&N is fully seated snug the rear section of the box to the front section and work the 4 clamps on the box closed. This is difficult, more brusied knuckles..the K&N is a little thicker that the stock Nissan paper filter so you really have to squeeze the box and work the clamps over till they snap into place.
8) Work the rubber tube back over the rear section tube and tighten the clamp.
9) Reinstall the hold down bolt and your good to go!
(Note: Disconnect the mass airflo sensor harness (electical connector) from the air box tube its easier to work with it out of the way....BUT!!!!!!do not start the engine with it disconnected. Connect it then start.
I have already notice an increase in gas milage with my K&N...you'll also do the same.
Growler
PS: I have previous posts on this subject on the Coupe forum. One title "K&N Filter Dry Run" and the second post "K&N in 10 minutes"
Old May 22, 2003 | 11:15 AM
Rumble's Avatar
Are you sure it's not psychological that you are feeling an increase in low end?
It's still a G thang!!
Old May 24, 2003 | 01:43 PM
DallyCurtis's Avatar
DUDE...
I must say ...that sig you have .... that is one hot mama.
I like
laterrrrrrrrrrr man
G35Rican
Jul 31, 2024 01:37 AM
Danielek
May 1, 2022 01:28 PM
mtlruss
Lighting
Sep 9, 2015 07:44 PM
JG_G35
Engine - Intake/Fuel
Sep 7, 2015 09:35 PM
