cylinder 4
Old Jul 18, 2006 | 07:38 PM
driguez's Avatar
cylinder 4
does any of you guys knows which is cylinder/ignition number 4?? i got a ses, cylinder 4 misfire, i just replaced the plugs so it might be a loose ignition, but as you may know to replace all of them its a bitch, so instead of going one by one and removing half the engine, i rather just know and go straight to the problem, anyways im thinking it might be like this:
windshield
1___2
3___4
5___6
bumper
anyone knows?? i tried searching here and google with no luck
Old Jul 18, 2006 | 08:55 PM
Audible Mayhem's Avatar
actually you have it backwards but 4 ends up being the same. one is front passenger......
Old Jul 18, 2006 | 09:07 PM
driguez's Avatar
so 4 is the same as i have it? good, now the problem was that when i changed the plugs that plug (4) had oil on the threads, i think the ignition might have had some oil left in it, damn it, or maybe the new plug got some oil when i inserted it, can i clean the ignition with carburator cleaner?? any tips on how to get it clean real good?? im going tomorrow to get another plug and take care of that, tips are very much welcomed, thanx
Old Jul 18, 2006 | 09:52 PM
what do you mean, the ignition?? you mean the coil??
some peoples valve cover gaskets were leaking into the coils, be careful with them cause they are expensive.
also make sure you torque the crush washer down on the new plug really good.
Old Jul 18, 2006 | 09:56 PM
driguez's Avatar
yes i meant the coil, i guess the gasket is leaking, but what im trying to say is this, the coil had some oil on it, what can i use to clean it?? bc im sure thats the problem
Old Jul 18, 2006 | 10:03 PM
now that i am not really sure about, i would go onto my350z.com and do a search, i am sure someone on there has posted about it.
good luck!!
Old Jul 18, 2006 | 10:04 PM
driguez's Avatar
good luck!!
thanx for your help
Old Jul 18, 2006 | 11:28 PM
SFLG35's Avatar
FGC President
how does that work if 1 is front passenger and 4 is in the same spot
what you sayin is it goes
2__1
3__4
6__5
that doesnt make any sense!!
arent all the evens on the drivers side and the odds on the passengers side
what are you takin as the front of the car windshield or bumper
i was takin windshield as front
here is a better diagram
front
d--p
2--1
4--3
6--5
rear
Old Jul 18, 2006 | 11:39 PM
i corrected you, so if you want to correct your post thats cool
odds on pass side, evens on driver side
i am assuming that he meant windshield as the rear part of the motor and the bumper as the front
then 4 would be in the same spot
Old Jul 18, 2006 | 11:43 PM
SFLG35's Avatar
FGC President
what??
shouldnt you be inbed by now
KallDay86
Jan 8, 2016 12:42 AM
alessandro
Oct 8, 2015 09:29 AM
AL8782
Oct 3, 2015 10:26 AM
dcsbh1
Oct 1, 2015 03:15 PM
bigmike
Sep 17, 2015 01:58 PM
