Stereo installs in Miami area?
Originally Posted by RedG
Hold on let me get this str8 you want to add a factory NAV to your car that doesn't have it, and then mod it to watch DVDs?
Originally Posted by escobar929
yeah think your talking bout the 4080 box, it a great box.
then get a 10w6 or something similar. if you're only gonna go w/ one speaker make sure its powerful enough
IMO if its a lease it would be easier to swap out the HU, that way the OEM HU stays untouched, then when its time to give the car back you can swap out everything yourself
++1
No im not saying it can't be done, but I think it will involve more than just adding the NAV unit. I was just trying to think on the best route to go. I would just switch the HU with a pioneer NAV for the double din or even better the alpine w200.
Originally Posted by MIAG35
good point. How hard would it be for the AC panel to be re-soldered?
it brought them everything, from dash kit, ac controller, sub, amp, box, HU, PAC unit.
all i got from them was the amp kit and the wiring. it came out to a lil over $300 for everything to be installed
dumb question, but what does double din mean?
yep, why is that crazy?? Im a rook!
From what I understand, you can't add a factory nav to a car that didn't come with it because of differences in the wiring harnesses. I also think it would likely cost as much, if not more, to install the factory nav in you non-nav car (if you could do it) than to install an aftermarket head unit with nav.
You definately need a bit a soldering skill to do the dual ac. You have to unsolder the button from your existing AC controller and resolder it onto the new one.
that it takes two slots
not crazy but a lot of work, when it could be a lot easier to swap out the HU
ok let me get this straight. Double din is when there are two slots and the HU would flip out of one of the slots? Or do you mean that it would be like an in-dash set-up? Thanks for taking the time to answer my questions fellas.
it would def be a in dash set up. if it was a single din, then it would be a flip out w/ an empty slot under, where most people put a lil open storage area.
here's a pic of mine if it helps
The old time standard radio size was governed by international standards. I forget exactly what DIN stands for, but in stereo head units it is the size of a standard, old-fashioned radio. They set a standard so all radios would fit all cars.
Most new cars avoid this and use OEM specific radio sizes... probably so everyone won't dump the OEM stereo and put in good stuff.
When stereo systems with video standards became popular, the standards committees made a new standard that was two single-DIN units stacked on top of each other. From then on the original DIN size was sometimes called single-DIN and the new, taller video size was called double-DIN.
sure bro np,
