if you are really worried about it mold it to the bumper. I know its a more expensive to do that but if you want the piece of mind mold it.
I used to use GE Silicon sealer for all kinds of stuff... intake manifold gaskets... sealing bolt-together wheels... how about using that along the top ridge? It wouldn't show because it drys clear.
The only down side would be that it might eat into the paint between the two pieces... but, it wouldn't ever show unless the lip came off.
ive got a clear bra on the bumper so that'll protect it. molding is too permanent and expensive. ill throw it on there with my idea friday and oh well if it comes off.
Quote:
tell me about it..im gonna order another one..Originally Posted by escobar929
dam Carlos, that sux
Quote:
Do you still have the broken lip? Can you post pics? What failed? The brackets?Originally Posted by Psycraft
Quote:
Quote:
^the tape failed. im thinking its not thick enough to stick adequately so thats why im going to try a double layer so make sure it contacts both surfaces.Originally Posted by Psycraft
it was the 3m tape that came with it that messed it up,i had it on less than a month and it got destroyed,the 3m tape came apart from the middle bumper and flew back under the bumper..unreal i have to say..their has to be a better way to put this thing
Quote:
yeah the tape failed,the brackets were perfect,thats what was holding the lip under the car while i was dragging it..im gonna try 3 layers of 3m tape i'll layer the whole thing i dont care..lolOriginally Posted by fbw5595
hopefully it doesnt rain tomorrow so i can put it on. i think 2 layers should be enough to reach but we'll see.
I just wanted to know if there was enough stress on the lip to break off near the brackets. Two layers of tape should fix it. I will do it this weekend.
tons of props to sean for his help and teaching yesterday. we got a ton done on my car - installed rear toe bolts, replaced front speed sensor brackets, replaced differential fluid and installed my new lip.
getting started
up she goes
diff fluid draining - so simple, only 2 caps
sean the perfectionist was smart enough to color the top of the tape so it doesnt show
bottom brackets
sections of tape - we used 3 layers but it seems 4 might have work better in some places
finished product
2 sweet g's
getting started
up she goes
bottom brackets
finished product
2 sweet g's
GreenGoblin
The goblin resurrection
close
- Join DateOct 2006
- LocationIn my garage
iTrader Positive Feedback100
iTrader Feedback Score(66)
Liked:187 Times in 95 Posts
very nice how much qts does the diff take and what fluid did u use
