built a camera headrest mount/shank nuts
Old Oct 2, 2009 | 08:39 PM
w0ady's Avatar
fgc moderator
so getting ready for my track days i did some surfing and just decided to build my own mount for my canon sd780is. rather than spend $40-50 online and i wanted to see some of my hand movement so did this.
i did vids in 720p but they're HUGE so ill have to make smaller 1s tomorrow and post them up.
also got some shank lugs in from summit racing. they're what you SHOULD run on oem g37 wheels.
$10 at home depot
mock-up
pipe insulation used to dampen vibration
only a couple screw-ups when drilling for the u-bolts
final product from my phone
widescreen view just like vids are made
3x zoom
flat lug base of the oem g37 wheel
tuner (cone) vs shank (flat)
and the sunset as i was walking in lol
Old Oct 2, 2009 | 08:46 PM
Nightm4re's Avatar
Looks good... i need to get a decent camera and make one of those lol
Old Oct 2, 2009 | 09:08 PM
w0ady's Avatar
fgc moderator
ya i recently replaced my sd850is with the sd780is. its a lot smaller and pic quality is better plus i get 720p video. plus i ran the 850 into a wall oops. 780 is pretty cheap now - around $250 i believe.
Old Oct 2, 2009 | 09:58 PM
ishiftinheels's Avatar
Teh Redhead Moderator
Nice. Get some vids up!
Originally Posted by w0ady
plus i ran the 850 into a pole oops.
fixed
Old Oct 2, 2009 | 10:19 PM
w0ady's Avatar
fgc moderator
right thats what i meant.
vids should be up tomorrow. ill try out the medium and low resolutions. just ran out of daylight today.
Old Oct 2, 2009 | 11:54 PM
Sen's Avatar
Sen
Sweet rig.
Old Oct 3, 2009 | 01:58 AM
Dranom's Avatar
nice woady! ill build one myself for our cruises
thanks!
Old Oct 3, 2009 | 02:19 AM
G U LATER's Avatar
I am about to build one as well
Old Oct 3, 2009 | 02:35 AM
w0ady's Avatar
fgc moderator
srsly. even its for fun - $10 and a hour or 2 and you're set. do it up!
Old Oct 3, 2009 | 02:44 AM
Kidcane's Avatar
Nice work Macgyver
Old Oct 3, 2009 | 08:21 AM
iamericgee's Avatar
what happened to the bubble gum additive?
Old Oct 3, 2009 | 08:31 AM
w0ady's Avatar
fgc moderator
what do you thinks holding on my splitter?
Old Oct 3, 2009 | 08:38 AM
iamericgee's Avatar
lol!!!!!!! looks good i need to get me one of those !
Old Oct 3, 2009 | 08:21 PM
w0ady's Avatar
fgc moderator
here are the vids i made over the last couple days with my new mount. tried all 3 resolutions and zoomed vs normal. decided im going with normal at lowest resolution for the first weekend. quality is decent enough and i can get much more footage to go over. plus i want the wider view of the track. i can always change the next time.
high res normal
high res 3x zoom
med res normal
med res 3x
low res normal
low res 3x
Old Oct 3, 2009 | 08:26 PM
iamericgee's Avatar
not bad there is little to no vibration !
